1. Here's a thread that needs an answer: W-a-a-y too many PSTs (Outlook 2003)
exchange webservices (EWS) authentication problem
Discussion in 'Exchange Server Questions' started by Sven Hornberg, Jun 3, 2009.
  1. Sven Hornberg
    Sven Hornberg
    Guest
    Hello enthusiastic developers,
    I'm currently trying to include exchange webservices 2007 functionality in a
    custom web application which is running on a Windows 2008 Server (IIS 7,
    Exchange Server 2007).
    How do I access exchange 2007 webservices from my web application ? I
    currently use the defaultcredentials and receive an error, saying I don't
    have the required authorization (error 401).
    Stating the credentials explicitly in the code works perfectly fine when
    trying to execute the code remotely, whether including the domain or not.
    When executing the code locally on either the web server or my client
    computer, no problems occur. The web application I intend to write is
    supposed to run on the server and be accessed from any computer via my
    company's intranet.
    The code looks something like this..
    ExchangeServiceBinding binding = new ExchangeServiceBinding();
    binding.Url = @"https://server/ews/exchange.asmx";
    binding.Credentials = System.Net.CredentialCache.DefaultNetworkCredentials;
    CreateItemType createItemType = new CreateItemType();
    > . (creating item and setting it's properties)
    try
    CreateItemResponseType createItemResponse =
    binding.CreateItem(createItemType); <- the error seems to occur here }
    catch (Exception ex) {
    Response.Write(ex.ToString()); <- results in error "unauthorized"
    The authentication settings in IIS 7 are as follows:
    anonymous authentication: deactivated
    ASP.NET multiple identities: activated
    digest authentication: deactivated
    forms authentication: deactivated
    standard authentication: deactivated
    windows authentication: deactivated
    User permissions set:
    SYSTEM: full access rights
    (windows user): full access rights
    IUSR: full access
  2. Henning Krause [MVP - Exchange]
    Guest
    are the web application and the Exchange server on the same server? If no,
    then you are experiencing a double-hop issue: NTLM tokens cannot be
    delegated. You either need Kerberos or basic authentication (the latter one
    over HTTPS to protect the password; But you loose single-sign on in this
    case).
    Kerberos on the other hand allows delegation and single-sign on. Google for
    Kerberos - there are plenty of tutorials available.
    Kind regards,
    Henning Krause
    "Sven Hornberg" <Sven Hornberg> wrote in message
    news:38922899-B7A1-4A34-B468-E9FC52979C52@microsoft.com...
    > a
    > company's intranet.
    > .. (creating item and setting it's properties)
    > try
    > IUSR: full access
Loading...
Share This Page
