Activesync and exchange 2003
  • Thread starter Tom Eirik Jensen
  • Start date Views 1,980
Tom Eirik Jensen
Hi!
I am using ISA server, exchange2003 and two domaincontrollers. One of them
is a CA. I have installed certificates to ISA and exchange for using outlook
webaccess. I am also using VPN with certs, and all is working fine.
Now I am trying to use activesync with my HTC Cruise Touch 2 with WM6.1.
Getting an error that
says my exchange server certificate is not valid. I have tryed to install
rootcertificate from my ca but no luck.
Are there some trick here? And which certificate, from what should I use?
L
Lanwench [MVP - Exchange]
Tom Eirik Jensen <tom.eirik.jensen@skjervoy.kommune.no> wrote:
> Hi!
> them is a CA. I have installed certificates to ISA and exchange for
> using outlook webaccess. I am also using VPN with certs, and all is
> working fine.
> WM6.1. Getting an error that
> install rootcertificate from my ca but no luck.
> use?
I'm not an ISA person, but you should be using the Exchange one, I believe.
However, I suggest you buy & install trusted certs. They're inexpensive
enough now and you don't have to jump through hoops on WM devices to make
this work.
Tom Eirik Jensen
Thanks for answer, I ordered a trial cert from Verisign. They had a good
website that explain everything.
Activesync worked fine after I installed cert.
Now I am going to bye a cert.
"Lanwench [MVP - Exchange]"
<lanwench@heybuddy.donotsendme.unsolicitedmailatyahoo.com> skrev i melding
news:%237a26XBxJHA.5100@TK2MSFTNGP04.phx.gbl...
> > Hi!
> > working fine.
> > use?
> believe. However, I suggest you buy & install trusted certs. They're
> inexpensive enough now and you don't have to jump through hoops on WM
> devices to make this work.
L
> good website that explain everything.
Cool. Don't waste your money on Verisign, though. Get a cheapo GoDaddy
one - $29/yr.
> melding news:%237a26XBxJHA.5100@TK2MSFTNGP04.phx.gbl...
> >> Hi!
> >> of them is a CA. I have installed certificates to ISA and exchange
> >> for using outlook webaccess. I am also using VPN with certs, and
> >> use?
Tom-Eirik Jensen
Thanks for advise...
news:uWoo7wS4JHA.5728@TK2MSFTNGP03.phx.gbl...
> one - $29/yr.
> >>> Hi!
> >>> use?
