BCM History 'From' field not populating
  • Thread starter MTech
  • Start date Views 2,198
MTech
When you list a history item within BCM, either through Projects, Accounts or
Business contacts. The 'From' field for an historical EMail is blank. Surely
this is a bug and should be fixed? Or, do I need to change/configure
something to allow this field to populate, I have looked all over but can't
find anything obvious to do this.
This post is a suggestion for Microsoft, and Microsoft responds to the
suggestions with the most votes. To vote for this suggestion, click the "I
Agree" button in the message pane. If you do not see the button, follow this
link to open the suggestion in the Microsoft Web-based Newsreader and then
click "I Agree" in the message pane.
?mid=8251ae98-16ca-48c2-92c0-b769e75f2f94&dg=microsoft.public.outlook.bcm
benzpilot
I am having exact same problem. I've done a pretty thorough search of the web
and no one seems to have answer.
It really limits the utility of linking emails to accounts if you can
readily see who it's from in the history...
> --------------> This post is a suggestion for Microsoft, and Microsoft responds to the
W
weddingsue
I am a new user and have exactly the same problem, it doesn't populate the to
& from email fields, nor the date and time sent and received, it just seems
to put the date and time that the history item was created. Very frustrating
as i want to be able to see the full communication history from each contact
without having to look in the sent and received email boxes. This must be a
bug as all the other irrelevant mail fields that you would never want to use
display ok!
