how to access BCM database after system restore
  • Thread starter AMAZINO
  • Start date Views 2,720
AMAZINO
#1
I do regular backups of my PC using a disk image software. My hardrive
recently had to be replaced due to to an unrecovereable error but I have
managed to restore the files. However, the image is not stable, so althought
I can access data, I have not been able to restore the PC "to its previous
stable state".
I have the BCM files from drive:\Documents and Settings\user\Local
Settings\Application Data\Microsoft\Business Contact Manager on my back
updrive as "normal, unpacked files", but I can not get BCM to see these. I
have copies these files to the reinstalled laptop (i.e. c: drive), but
outlook still does not see the database.
How can I get BCM to see the databese? Is there something I need to do
through SQL?
Many thanks,
Andrew
AMAZINO
#2
I have found the solution
http://www.mydatabasesupport.com/fo...ach-sql2005-database-different-directory.html
QUOTE:
Use SQL Server configuration manager from SQL Server 2005 program
goups...There select sql server 2005 services and choose sql server service
and see the Logon account.
If the account is not local system then change it to Local system and then
restart the service and see if the attch works. If it works then give the
necessary previlages to the
toher account and restart the service and see if the attach works fromm D
Drive..
Hari
> stable state".
> through SQL?
> Many thanks,
> Andrew
AMAZINO
#3
Drive..
Hari
> stable state".
> through SQL?
> Many thanks,
> Andrew
AMAZINO
#4
Drive..
Hari
> stable state".
> through SQL?
> Many thanks,
> Andrew
AMAZINO
#5
Drive..
Hari
> stable state".
> through SQL?
> Many thanks,
> Andrew
AMAZINO
#6
Drive..
Hari
> stable state".
> through SQL?
> Many thanks,
> Andrew
AMAZINO
#7
Drive..
Hari
> stable state".
> through SQL?
> Many thanks,
> Andrew
