_MailItem::Move fails
  • Thread starter tnemec78@googlemail.com
  • Start date
During many days of testing of my Outlook add-in I came across an
interesting problem:
Every now and then my call to _MailItem::Move fails. I have no idea
why that is. I only observed that in such situations the Move
operation acts as a copy and it returns a failure status.
See below:
void MoveItem(CComPtr <Outlook::_MailItem> mi, CComPtr <MAPIFolder
newfolder)
HRESULT hr;
CComPtr <IDispatch> ReturnedItem;
hr = mi->Move(newfolder, &ReturnedItem);
if( FAILED( hr ))
//here ReturnedItem == 0x00000000 although I can see that
the item *EXISTS* in the new folder
// ... more code ...
Although the new instance of the item exists, the old one was not
deleted. Despite this the ReturnedItem (ie. the new instance == 0)
Does anyone else have more experience with this issue? I would like to
know more about what can cause this, how to prevent this from
happening. If there is no way to do this then I suppose I only have to
mitigate the impact of this happening.
when Move fails then hr == 0x8004010F (MAPI_E_NOT_FOUND)
J MailItem.Move Outlook VBA and Custom Forms 1
G Event when creating task from mailitem Outlook VBA and Custom Forms 2
oliv- How to select an mailitem in explorer with "show as conversation" Outlook VBA and Custom Forms 8
JorgeDario How to capture and save the text, when responding a MailItem? Outlook VBA and Custom Forms 3
JorgeDario how to check a MailItem has a digital signature (SMIME) with vba? Outlook VBA and Custom Forms 1
JorgeDario ¿What property of mailitem can be used like primary key? Outlook VBA and Custom Forms 6
C MailItem Find method doesn't work Using Outlook 0
C MailItem.SaveAs not working Outlook VBA and Custom Forms 10
G RE:The signature is also inserted if you touch the MailItem. Outlook VBA and Custom Forms 1
B Add signature to MailItem Outlook VBA and Custom Forms 3
C How can I create a new MailItem inside a user folder? Outlook VBA and Custom Forms 4
S Create a new Outlook MailItem in an Outlook folder(not a draft) Outlook VBA and Custom Forms 2
A How to get OOM MailItem Raw data Outlook VBA and Custom Forms 2
S Saved Property of MailItem is copied Outlook VBA and Custom Forms 1
S MailItem Find Method question Outlook VBA and Custom Forms 6
N Getting the attachments in MailItem Outlook VBA and Custom Forms 1
S ->[O2007] Parsing each line of a MailItem HTMLBody? Outlook VBA and Custom Forms 2
T How to get Inspector or MailItem from wordEditor Outlook VBA and Custom Forms 6
A Select the position of an attached file in a HTML mailitem Outlook VBA and Custom Forms 1
M MailItem object has no property for when a reply was sent Outlook VBA and Custom Forms 3
B Insert information to MailItem Outlook VBA and Custom Forms 1
E Properties added to MailItem in ItemSend event visible to recipien Outlook VBA and Custom Forms 1
V Setting HTMLBody of new mailItem Outlook VBA and Custom Forms 1
V How to find mailitem in the inspector is a brand new one Outlook VBA and Custom Forms 2
M Activate "Add digital signature to this massage" on a MailItem? Outlook VBA and Custom Forms 1
K importing EML in MailItem Outlook VBA and Custom Forms 1
A mailitem Send issue Outlook VBA and Custom Forms 5
M Get email address from MailItem.To? Outlook VBA and Custom Forms 6
S UserProperties of MailItem object. Outlook VBA and Custom Forms 3
R How to capture a Mailitem Event Outlook VBA and Custom Forms 3
S get current position in message body of mailitem Outlook VBA and Custom Forms 8
S How to get RFC822 format message from the MailItem object. Outlook VBA and Custom Forms 4
D MailItem from an RSS feed Outlook VBA and Custom Forms 2
J Outlook 2007 crashed when pushing send on a displayed mailitem Outlook VBA and Custom Forms 1
N Memory with MailItem.Send Outlook VBA and Custom Forms 1
P Adding a button in a mailitem Outlook VBA and Custom Forms 1
D Max. length of MSO MailItem.EntryID Outlook VBA and Custom Forms 6
R MailItem.Display() error Outlook VBA and Custom Forms 1
R Clone mailitem Outlook VBA and Custom Forms 5
R MailItem Outlook VBA and Custom Forms 2
