Controls in message body
C
Chris Szabo
Good afternoon everyone. I'm completely new to Outlook Forms and I just have
a few basic questions.
The goal of the project I'm working on is to have a message template with
different controls in the message body itself. So, for instance, one field
might be a person's name, so there would be a textbox control with a label
for their name. There could be a check box to indicate that the "person"
belongs to a particular group in the message body. There could be a drop
down list in the message body that has one of several categories that a user
should select from.
Once the "message" is complete, it would be emailed to someone else who
would be responsible for filling in other controls within the message. I
have played with the form designer, and I can add controls to a message,
however they do not appear in the received message after it has been sent.
Is what I'm trying to accomplish something that can even be done with
Outlook Forms, or is this outside the capabilities of this particular feature?
Thanks in advance.
Unless you send out the form to a recipient who has that form published on
their computer or in an organizational forms library that would never work.
Even then the preview pane won't show that sort of content from a custom
form, it won't show anything.
See the forms information, especially the information about sending custom
forms, at www.outlookcode.com to see why this is a bad idea and what the
alternatives are.
"Chris Szabo" <ChrisSzabo> wrote in message
news:8929B1F9-9574-4C16-A52D-380AE081C00A@microsoft.com...
> have
> field
> user
> should select from.
> feature?
> Thanks in advance.
GregS What controls content of Folder Pane? Using Outlook 1
H What Controls what is shown in the preview pane Outlook VBA and Custom Forms 1
C Printing Outlook Form Controls via Word Using Outlook 11
B Adding controls programmatically Using Outlook 1
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 2
E VSTO 2008 how to bind Form Region controls to Item data fields Outlook VBA and Custom Forms 3
A Command Button Controls Outlook VBA and Custom Forms 6
M Adding controls in the Email Form Outlook VBA and Custom Forms 1
A Controls in VBA Outlook VBA and Custom Forms 4
O Integration with 3rd-party controls Outlook VBA and Custom Forms 2
T How to delete the controls in a CommandBarPopup? Outlook VBA and Custom Forms 1
N Junk Mail Controls Outlook VBA and Custom Forms 1
G Custom controls not functioning? Outlook VBA and Custom Forms 1
P New outlook controls Outlook VBA and Custom Forms 4
C Difference between the TabStrip and MultiPage controls?? Outlook VBA and Custom Forms 2
M A plug in (or method) to keep email message formatting after it expires Using Outlook 1
M Search message, then (1) Jump to folder & (2) Select message that you searched for Outlook VBA and Custom Forms 7
F Outlook 2019 Forwarding Message and Keeping Unread Status Outlook VBA and Custom Forms 0
A rule name into message - how? Outlook VBA and Custom Forms 5
A Links in email getting error message about group policy Using Outlook 4
Commodore Unable to move message Using Outlook 3
Y Disable Microsoft Outlook Test Message Using Outlook 4
S Unable to change Message Class Outlook VBA and Custom Forms 0
S Changing Message Class Outlook VBA and Custom Forms 4
Cathy Rhone Mail merge error message Using Outlook 1
Cathy Rhone The properties of the message have been changed Using Outlook 1
S Outlook 2016 A Shortcut to recall and delete and sent message. Using Outlook 1
S Unable to extract text from an Outlook email message Using Outlook 2
R Outlook 2016 Message-ID oddity/inconsistency? Using Outlook 7
