Delegates page is not Availuable...
  • Thread starter Q Logic, Ltd.
  • Start date Views 5,337
Q
Q Logic, Ltd.
#2
test responce....
"Q Logic, Ltd." wrote:
> Does anybody have any suggestions on this? I posted a question about a week
> ago and recieved no responce... I located similar issues that refured to:
> http://support.microsoft.com/kb/253557
> But this does not help, or work with Exchange 2007 or x64 systems....
N
Nikki Peterson
#3
If you remove the following Exchange Extention from the client
machine, the DELEGATES tab will not show:
DLGSETP.ECF
So, if it is just the client that is unable to see the Delegates tab
see if this is missing from the Add-Ins. If so, re-add and enable
it.
Nikki
"Q Logic, Ltd." <QLogicLtd> wrote in message
news:3A2002A4-8750-4E0A-86DE-58DAE2242FD3@microsoft.com...
test responce....
> week
Q
Q Logic, Ltd.
#4
I will try, but as I mentioned I tried setting up his mailbox on many
different machines, some XP, some Vista running Office 2003 or Office 2007
and it was the same on all of them... But I will give this a try and get back
to you...
> DLGSETP.ECF
> it.
> Nikki
> test responce....
> > week
Q
Q Logic, Ltd.
#5
It was enabled, I even tried disabling it and re-enabling it, with no effect,
other then while it is disabled the tab does not even show up....
The specific message that shows up when I go to that tab is "The Delegate
page is unavailuable. Cannot access Outlook folder."
> DLGSETP.ECF
> it.
> Nikki
> test responce....
> > week
N
Nikki Peterson
#6
Have you looked at: http://support.microsoft.com/kb/199964
Error message in Exchange Server: "The Delegate page is not
available. Unable to access Outlook folder."
Nikki
news:00DD1502-487F-4402-8DD6-2789287EB241@microsoft.com...
effect,
> DLGSETP.ECF
> it.
> Nikki
> test responce....
> > week
> > to:
Q
Q Logic, Ltd.
#7
That sounds like the issue, unfortunatly step #2 in the work around applies
only to Exchange 2000 or Exchange 5.5... I am extremly hestitent to try to
apply these instructions to an Exchange 2007 x64 system... I would say 80% of
the Exchange tools refured to in these articles were not designed for use on
Exchange 2007 or an x64 envirnment...
> Nikki
> effect,
> > DLGSETP.ECF
> > it.
> > Nikki
> > test responce....
> > > week
> > > to:
N
Nikki Peterson
#8
If you are uncomfortable with the ADSI edit, the First solution would
be the way to go. Just make a PST of the contents of the mailbox and
build a new one.
Nikki
news:826B54AB-083A-46A2-A1E1-1B05E3F13FBC@microsoft.com...
of
> Nikki
> effect,
> > DLGSETP.ECF
> > it.
> > Nikki
> > test responce....
> > > week
> > > to:
Q
Q Logic, Ltd.
#9
Actually my client is more uncomfortable with the possiable results of
deleting and re-creating his mailbox... I have no issue using the other steps
but all the instructions are designed around the toolbox from Exchange
2000... From my experience most of these work similar but not the same... I
have checked the values indicated in these instructions and there is no
difference between a user that is working and the one that6 is not... The
value of all users are the same....:
CN=Microsoft MTA,CN=RAL-NYC-2008,CN=Servers,CN=Exchange Administrative Group
(FYDIBOHF23SPDLT),CN=Administrative Groups,CN=RALCOMPANIES,CN=Microsoft
Exchange,CN=Services,CN=Configuration,DC=RALCompanies,DC=local
> build a new one.
> Nikki
> of
> > Nikki
> > effect,
> > > > DLGSETP.ECF
> > > it.
> > > > Nikki
> > > test responce....
> > > > week
> > > > to:
Q
Q Logic, Ltd.
#10
Nikki,
Thanks for all the suggestions, but I have proformed all the steps
documented in that article except for destroying and recreating the
mailbox... And it has had no effect... Although in the end of step #2 it asks
you to force a replication and choose "Replicate Now", I can not find this
command in Exchange 2007, so I restarted all Exchange services but it also0
had no effect....
QLogicLtd
> Nikki
> effect,
> > DLGSETP.ECF
> > it.
> > Nikki
> > test responce....
> > > week
> > > to:
Rich Matheisen [MVP]
#11
On Fri, 12 Jun 2009 22:00:01 -0700, Q Logic, Ltd.
<QLogicLtd> wrote:
> Nikki,
> had no effect....
Sometimes it's not Exchange, or Outlook, that's the problem. How about
the permissions on the AD user object? Is, for example, the
inheritance of permissions allowed or denied on the user object?
Rich Matheisen
Q
Q Logic, Ltd.
#12
I'm not really sure, where would this be specified? I had to move all users
into a stripped down OU as the default groups and SBS 2008 Console just kept
over righting group permissions....
> <QLogicLtd> wrote:
> >Nikki,
> >had no effect....
> -> Rich Matheisen
N
Nikki Peterson
#13
The "Send As" right is removed from a user object after you configure the
"Send As" right in the Active Directory Users and Computers snap-in in
Exchange Server: http://support.microsoft.com/kb/907434/
The following list contains the protected groups:
• Administrators
• Account Operators
• Server Operators
• Print Operators
• Backup Operators
• Domain Admins
• Schema Admins
• Enterprise Admins
• Cert Publishers
Nikki
news:54853E6C-29D8-43F0-997C-B09F476E3656@microsoft.com...
> <QLogicLtd> wrote:
> >Nikki,
> >asks
> >this
> >also0
> >had no effect....
> -> Rich Matheisen
#14
On Sat, 13 Jun 2009 20:44:01 -0700, Q Logic, Ltd.
Select the "Security" tab on the user's properties. Then click the
"Advanced..." button. There's a checkbox that will e checked if
inheritance is alowed or unchecked if it's denied.
That's something to bring up in a SBS newsgroup. SBS is "overly
helpful" in many cases.
Rich Matheisen
Q
Q Logic, Ltd.
#15
Then inheritance is denied (unchecked)... II've checked a few other users and
some have it unchecked and some have it checked.... This may have been the
same inheritance button that related to the email address in Exchange 2003...
That would explain why some users are checked and others are not....
> -> Rich Matheisen
#16
On Sun, 14 Jun 2009 20:09:01 -0700, Q Logic, Ltd.
If permissions are not inherited then the user may be (or was, at some
point) a member of a "protected group". In that case the property
"adminCount" will be greater than 0 (usually it's only "1"). This can
lead to lots of hard to figure out problems. If you check the box, set
admincount to zero, and wait a couple of hours does the checkbox
remain checked? If it does then the user isn't a member of a protected
group. If the inhertance is blocked again then they are a member of a
protected group.
You need to decide what accounts are used for "normal" work and what
accounts are used for "administrative" work. Giving someone a 2nd
account for the admin work and removing their "normal" account from
the protected group(s) (and unblocking inheritance and setting
adminCount to 0) should make things work a lot smoother.
Whether that "fixes" your original problem or not I don't know, but
it's certainly removing one troublesome thing from the list.
The Recipient Update Service needs access to the user accounts to give
them the necessary permissions and addresses. If the RUS is denied
access to the account things won't go well.
Rich Matheisen
