1. Here's a thread that needs an answer: Shared Mailboxes and the Default 'Send From' Account
How do I fix "prop bitmap dll not loaded"?
Discussion in 'Using Outlook' started by Kaz0159, Jun 15, 2009.
  1. Kaz0159
    Kaz0159
    Guest
    I click to print an email and receive "prop bitmap not loaded". I click on
    ok, then the email prints. It never used to do this... can anyone assist?
    Please let me know. Thanks!
  2. K. Orland
    K. Orland
    Guest
    This is a printer issue, not an Outlook issue. Have you installed the latest
    drivers for your printer?
  3. wculbertson
    wculbertson
    Guest
    I have had the same thing happen with a Lexmark X7130 printer. I
    downloaded the latest drivers, removed the ones currently installed
    before installing the new ones. This didn't help. I then checked
    Microsoft's Knowledge Base, found nothing referring to this topic, so I
    contacted Lexmark. They told me it is not a printer issue, but an
    Outlook problem. It seems I am going in circles with this one.
    Just a few things to mention in specific - it only happens with
    Outlook, and it only happens one time; and the first time I print after
    starting the computer. After I close the error notice, it does not
    appear again, until after I restart my computer. If I print from any
    other application before Outlook, it will not happen with Outlook.
    Now, this might sound like an Outlook problem, except that it only
    happens with this Lexmark printer. No other printer in our office, and
    we use several HP's, Epsons, and Brothers. I am not sure where to point
    the finger any longer. I just need some good guidance.
  4. Brian Tillman
    Brian Tillman
    There have been many instances of Lexmark printers evincing this issue. If
    you Google that error, in the majority of cases, the web site found will
    mention either "Lexmark" or "Dell". Many of Dell's printers are rebranded
    Lexmarks.
    Start Outlook in safe mode (hold Ctrl when you start Outlook) and see if that
    makes any difference.
  5. wculbertson
    wculbertson
    Guest
    OK, I started Outlook in safe mode, and the same thing happened. When I
    printed from Outlook to the Lexmark printer, as the first print job
    after booting the computer I got the error.
    I did try something else as an experiment this morning also, and was
    somewhat surprised. Right after booting, I printed from Outlook to one
    of our other printers on the network (the Lexmark printer is not
    networked), and did not get the error; I then printed to the Lexmark and
    got the error. I had not done this routine before, so was surprised when
    this happened. I know if I print from a different application first then
    Outlook, the error does not occur.
    Needless to say I am still confused.
Loading...
Share This Page
