Programmatically bring up Advanced Find for contacts?
  • Thread starter StargateFanNotAtHome
  • Start date
I've found numerous posts regarding the regular email message advanced
find, but nothing about the advanced find for contacts. It's now more
mouse clicks to get to and I have to search a few times a day for
names within my organization. Would be neat to have vb to bring it
up.
The way to get to it in O2007 that I've found is:
Click on NEW MAIL message > TO box > ADVANCED FIND link in upper right-
hand corner of that box.
Anyone know how to bring up the box directly via vb script?
Thanks! :eek:D
Get the CommandBars collection of the Inspector and call the
CommandBars.ExecuteMso() method with an argument of "AdvancedFind".
"StargateFanNotAtHome" <StargateFanNotAtHome@mailinator.com> wrote in
message
news:027b33dd-fa80-4815-8b11-cb9e08a7488d@w9g2000pro.googlegroups.com...
> up.
> Thanks! :eek:D
Dr. Demento Programmatically encrypt email (2010) Using Outlook 10
oliv- Reduce the size of picture attachments: programmatically Outlook VBA and Custom Forms 3
B Adding controls programmatically Using Outlook 1
M programmatically make all Appointmentitem olResource Attendees unsendable Using Outlook 1
S Programmatically accessing Outlook Calendar data Using Outlook 1
R Send appointments data to a Form programmatically Outlook VBA and Custom Forms 2
M How to connect to SQL DB from outlook programmatically? Outlook VBA and Custom Forms 1
B Programmatically scheduling WebEx meetings through Outlook Outlook VBA and Custom Forms 1
N Help in programmatically setting formatting in an AppointmentItem Outlook VBA and Custom Forms 3
K Programmatically accessing Outlook properties Outlook VBA and Custom Forms 3
V How to programmatically set "Display reminders and tasks frm pstfolder Outlook VBA and Custom Forms 1
R Displaying a field from the field chooser programmatically Outlook VBA and Custom Forms 1
M How to programmatically select a outlook search folder? Outlook VBA and Custom Forms 1
M How to install custom mapi form programmatically? Outlook VBA and Custom Forms 1
A Programmatically duplicating BCM's "Link to Record" function BCM (Business Contact Manager) 2
B Accessing Outlook 2003 Signature Programmatically using C# Outlook VBA and Custom Forms 6
L Programmatically moving between pages in a form Outlook VBA and Custom Forms 2
S assign task programmatically Outlook VBA and Custom Forms 2
S do Reply, Reply to All, Forward programmatically Outlook VBA and Custom Forms 2
O looking to bring in all my folders from Outlook Express (XP) to Outlook 2013 Using Outlook 3
S Related messages show in main Outlook window vice new Advanced Find windows Using Outlook 1
O Advanced search - can I use booleans Using Outlook 3
H "Advanced find: column for full folder path? Using Outlook 1
Andrew Hawkins "Advanced Find" Using Outlook 1
P Outlook Advanced Find Using Outlook 0
S Advanced Find text field limits Using Outlook 2
C O2010: Using Advanced Find to locate exact queries Using Outlook 3
N Outlook 2010 crippled Advanced Find, now what? Using Outlook 3
H Outlook 2010 Advanced Find - Menu items missing Using Outlook 1
D Outlook 2010 - Advanced Find - No Status Bar = No Item Count Using Outlook 2
J How to filter by address fragment (e.g. "@domain.com") with advanced find? Using Outlook 2
P Open Advanced Search Dialog Outlook VBA and Custom Forms 1
