Outlook AddIn can't load outside Visual Studio
dxider
Hi, I'm trying to deploy a Outlook AddIn into various computers.
The AddIn is programmed in C# using VS2008, it works when I run it inside
Visual Studio IDE, but when the project is installed via the Setup project,
Outlook won't load the AddIn, if I try to load it manually, Outlooks displays
an error indicating that the AddIn is not a valid Office Complement.
I even tried to load it from the project bin/release folder in the same
computer where is programmed, but Outlook cant load it, same error.
The project uses CDO to get some inaccesible properties, CDO is already
installed and works without problems when project is loaded from VS.
Can someone give me a clue to solve this problem?.
Thanks in advance.
Dream it, love it, CODE IT!!!
Do not use CDO 1.21 with managed code, it's not supported and will break
just you when need it most. There are memory leaks and problems with memory
management and MS will not support that usage at all, and neither will we.
For deployment issues see
http://blogs.msdn.com/vsod/archive/2008/04/22/Troubleshooting-com-add-in-load-failures.aspx
"dxider" <dsider@hotmail.com> wrote in message
news:BEB62DC6-1EAB-434C-89B5-6532210E6E21@microsoft.com...
> project,
> displays
> Thanks in advance.
Diane Poremsky Always Load an Outlook Addin Using Outlook 1
S COM Addin Failed to load in Outlook 2003 Outlook VBA and Custom Forms 1
W My VSTO 3.0 Outlook addin doesn’t load Outlook VBA and Custom Forms 1
S Outlook 2016 and Acrobat PDFMaker Office COM Addin Using Outlook 0
D Constant Dropbox Outlook Addin Authentication Prompts Using Outlook 5
C Outlook 2010, Need to restrict domain users from installing any sort of a addin in outlook Using Outlook 2
M Icloud Addin in Outlook 2013 Exchange Server Administration 9
H Outlook 2010 Antispam Addin Not Available Using Outlook 1
C Connecting to an addin in Outlook 2010 (or not) Outlook VBA and Custom Forms 1
T Regarding Outlook addin Outlook VBA and Custom Forms 1
N Drag and drop attachment in outlook addin Outlook VBA and Custom Forms 4
S Outlook addin formregion as a drop down Outlook VBA and Custom Forms 6
K Attach addin to outlook 2007 editor Outlook VBA and Custom Forms 3
T need help w/ sending an e-mail -- outlook 2007 addin Outlook VBA and Custom Forms 2
N VSTO outlook 2007 addin installation problem Outlook VBA and Custom Forms 1
N Support for outlook 2003 addin in xp home sp2 Outlook VBA and Custom Forms 3
R Hi, Ken, What should be noticed to avoid memory leak in outlook addin? Outlook VBA and Custom Forms 3
T Simple MAPI send and Outlook COM addin Outlook VBA and Custom Forms 3
U Outlook Addin Creation using Visual Studio 2008 Outlook VBA and Custom Forms 1
E Opening WinForm in Outlook 2003 VSTO Addin with Wordmail enabled Outlook VBA and Custom Forms 1
D Outlook 2007 AddIn: Rendering issue Outlook VBA and Custom Forms 1
D Outlook 2007 AddIn: Filter attachments by type Outlook VBA and Custom Forms 2
e_a_g_l_e_p_i Question about Outlook 2021 and Gmail Using Outlook 8
J Outlook VBA to send from Non-default Account & Data Files Outlook VBA and Custom Forms 2
P Limited Support for 3rd Party Mail in new Outlook? Using Outlook 1
T Outlook is categorizing emails incorrectly Using Outlook 1
R Legacy Outlook on Mac Email Cache Using Outlook 0
A Outlook can't remember outlook.com, Exchange password. Using Outlook 3
S Related messages show in main Outlook window vice new Advanced Find windows Using Outlook 1
H Force Outlook 2019 with GMail 2-Step to Require Login? Using Outlook 0
G Retaining Tabs in outlook body Using Outlook 2
V Setting up Outlook 2021 on new computer Using Outlook 2
D Delete Outlook emails from MS server Using Outlook 12
B Outlook tasks and PDF Using Outlook 4
D Outlook 2019 is no longer asking for password ... Using Outlook 5
L Outlook attachments from OneDrive as links Using Outlook 0
