After being read, emails disappear
  • Thread starter QnJhZHdpbg
  • Start date Views 10,487
Q
QnJhZHdpbg
Using Outlook 2007, after reading a new email, it shows read. When
navigating to another folder and returning to the Inbox, the messasge has
disappeared from the inbox. Searching for the message shows it present in
the inbox. It cannot be be re-read except through the searching process.
Bradwin
N
neo [mvp outlook]
Sounds like you might have modified your view to hide read items. You can
either reset your view via View > Current View > Define Views or start
Microsoft Outlook 1 time with the /cleanviews command line switch. I will
warn you that if you use the /cleanviews command line switch, it will reset
all built-in view back to their defaults and delete all custom views.
"Bradwin" <Bradwin> wrote in message
news:B4542687-4165-4C7C-A991-40328F2BF252@microsoft.com...
> Bradwin
Q
QnJhZHdpbg
I should have been a bit clearer. Not every email "disappears" after being
read, and those that do, don't immediately disappear, only after navigating
away from the inbox. I will attempt to reset the defined views, however.
Thank you. Bradwin
> > Bradwin
Are you using Exchange server mailbox, a pop or imap account?
news:94CE3DD6-2D49-4C14-A383-63A983831D1B@microsoft.com...
> being
> navigating
> Thank you. Bradwin
> > can
> > will
> > reset
> > > has
> > > in
> > > process.
> >> > Bradwin
W
WHRyZW1l
I have the same issue and it seems to happen random and not very frequently.
Please let me know if you have an answer.
Owner/engineer
RW1haWxNYWdpY2lhbg
I have had the same problem with Outlook 2007 (on a vista computer) and a
Gmail account using IMAP. If it matters, that email is IMAP'd to another
computer winth Outlook 2003, and a Blackberry. However it doesn't happen to
all emails, and the Blackberry nor the outlook 2003 ever delete the messages.
It just seems to happen randomly. Sometimes the emails are moved to the
junk folder, but that is less than 10% of the time. The rest they just
disappear completely. At first I didn't believe my fiance when she told me
it was happening, but when using her computer I saw it with my own eyes.
Please offer any advise on this issue
manusoft
Outlook 2007
I have a user with the same problem.
On rare occasions, most of her read messages dissappear from her inbox (outlook 2007, exchange 2003 server).
She also has an iPhone which receives incomong mails.
Has anybody got a solution for this strange problem?
Jam88es99
Outlook 2007
