sort over flagstatus
K
King Albert
In my inbox I have a folder "Servers"
That folder is populated by mails that either I moved or created there
using VBS. The script flags these mails Red, Green, Blue and Yellow based
on different criteria.
As a final step the script needs to sort (or rather group) these mailitems
by flagcolor. When I arrive at work I want my server reports grouped by
color.
I came across items.sort "somekey" , started looking for its "flag"
equivalent and then read a disconcerting post from Sue Mosher that sorting
this way isn't going to cut it in the GUI anyway.
please give me a few pointers to solve this
thx
Ward
Have you tried using the View | Current View | Define Views command to
create a new named view with the layout you want? If you continue to have
problems with this, please state your Outlook version.
Sue Mosher
"King Albert" <king.albert2@forpresident.com> wrote in message
news:Xns9C40916EF1F9kingalbert2forpresid@69.16.176.253...
> Hi,
> color.
> thx
> Ward
I hadn't thought of that, but I tried it just now.
In the GUI it works: if I select the "Servers" view mailitems are sorted
by flagcolor.
In the script I added this line I discovered in one of your previous
ol.ActiveExplorer.CurrentView = "Servers"
But it didn't change the default view in that folder after it ran (with
on error switched off and no faults)
The script expects its mails in the Servers folder, when runs it creates
a new subfolder
With serverfolder
Set nieuwefolder =.Folders.add("Servers " & Date)
and then starts to flag and move the mailitems. Every run it deletes the
folder from 7 days ago.
It would be cool if we could attach the "Servers view" to these newly
created folders.
Target is Outlook 2003
thank you !
Ward
"Sue Mosher [MVP]" <suemvp@turtleflock.com> wrote in
news:uiopkgj$JHA.200@TK2MSFTNGP05.phx.gbl:
> have problems with this, please state your Outlook version.
From your description, it sounds like Servers may be a view with the scope
"on this folder visible to everyone," which means it cannot be used on other
folders. Make a copy of that view with the scope "on all Mail and Post
folders," so that it can be used on any folder.
Sue Mosher
news:Xns9C409B7E24870kingalbert2forpresid@69.16.176.253...
> by flagcolor.
> posts :
> a new subfolder
> With serverfolder
> created folders.
> thank you !
> Ward
>> Hi,
> > mailitems
> > color.
> > sorting
No it was right first time, but I did trip over objectvariable references
like I shouldn't anymore :)
Set ol.ActiveExplorer.CurrentFolder = nieuwefolder
Thank you very much !
Ward
news:#4YTyMk$JHA.4376@TK2MSFTNGP04.phx.gbl:
> scope "on this folder visible to everyone," which means it cannot be
> used on other folders. Make a copy of that view with the scope "on all
> Mail and Post folders," so that it can be used on any folder.
Witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
King Mustard Sort search groups by amount of items? Using Outlook 1
D [TOOL] QuickModules to sort emails very quickly to multiple folders Outlook VBA and Custom Forms 1
A Sort emails into subfolders based on sender and deleting emails automatically Outlook VBA and Custom Forms 3
Diane Poremsky Sort messages by Sender domain Using Outlook 1
J Can I sort meeting requests by the date of meeting? Using Outlook 4
P Is it possible to sort emails by COUNT of "From" field? Using Outlook 2
L Sort bar at top of inbox preview outlook 2013 Using Outlook 1
C Outlook 2010, Need to restrict domain users from installing any sort of a addin in outlook Using Outlook 2
J How to sort incoming email that is sent to a different address to my main one? Using Outlook 1
D Contacts Sort Order Using Outlook 0
kburrows Office 365 - Contacts Sort First, Last instead of Last, First. How to Reset? Using Outlook 4
I 2013 Calendar sort date Using Outlook 3
J outlook having sort by date or from unable to display sender name. Using Outlook 2
J Macro to periodically sort emails by flag status? Using Outlook 1
2 Sort taks by folder then by date? Using Outlook 5
S Outlook 2007 Sort Column Shading Using Outlook 1
S Public FolderEmail Sort Problems Outlook 2010/Migration from 2003 SBS to 2011S Using Outlook 3
D Sort e-mail by sender's domain - Outlook 2007 Using Outlook 2
B outlook sort by Using Outlook 2
A Sorting of existing contact in Outlook 2003 just will not sort Using Outlook 2
J Outlook 2010 Inbox sort FROM column not working Using Outlook 29
S changing number sort BCM (Business Contact Manager) 1
B Macro to Change sort and collapse groups in Mail folder Outlook VBA and Custom Forms 9
L Interating throught a task list, respecting sort rules in the view Outlook VBA and Custom Forms 1
A How to Sort by Unread and then Read mail in Outlook 2007 Using Outlook 7
S How do i sort email by Domain? Outlook VBA and Custom Forms 2
