Hiding private appointment on my own machine
  • Thread starter Stephane Barizien
  • Start date Views 1,449
Stephane Barizien
Our corp policy is that when working in a meeting room we just RD [connect
with Remote Desktop] to our own desktop from the meeting room's PC.
A side effect is that when you navigate in Outlook (or get reminders,
whatever) everyone in the room can see private appointments.
Is there a means to tell Outlook not to display YOUR private appointments in
YOUR Outlook session?
Judy Gleeson \(MVP Outlook\)
You could make a View that filters out Private appointments and set it to
that View when you are the meeting room.
Turn off Reminders for that day's appointment manually.
Regards
Judy Gleeson
www.judygleeson.com
"Stephane Barizien" <sba@nospam.nospam> wrote in message
news:uSNh1grBKHA.3800@TK2MSFTNGP04.phx.gbl...
> in YOUR Outlook session?
Does the computer project to a large screen visible to everyone? Only people
looking over my shoulder can see my calendar when I do this unless the
screen is projected - in that case, close outlook or if you are training in
outlook, make a new profile to a test mailbox. You shouldn't use your live
mailbox for training.
You can turn off reminders or close the reminder dialog... for events you'll
need to a custom view that hides appointments you don't want to see. If you
are using your system to run a powerpoint, close outlook.
Stephane Barizien
I'll give the "view" trick a shot.
Thx.
> it to that View when you are the meeting room.
> Regards
> Judy Gleeson
> www.judygleeson.com
> > [connect with Remote Desktop] to our own desktop from the meeting
> > room's PC. A side effect is that when you navigate in Outlook (or get
> > reminders,
> > appointments in YOUR Outlook session?
Stephane Barizien
Typically, yes, the situation is that the screen is projected, then at some
point of the meeting the discussion moves to "when can we have the next
meeting" at which point I have to bring up Outlook...
> people looking over my shoulder can see my calendar when I do this
> unless the screen is projected - in that case, close outlook or if
> you are training in outlook, make a new profile to a test mailbox.
> You shouldn't use your live mailbox for training.
> you'll need to a custom view that hides appointments you don't want
> to see. If you are using your system to run a powerpoint, close
> outlook.
> > reminders,
Stephane Barizien
This works like a charm.
Thx for the tip.
> Regards
> Judy Gleeson
> www.judygleeson.com
> > reminders,
