Re: Opening a specific Custom form with a macro
DawnTreader
Hello Sue
can i use something like you have mentioned in your post to push a form to
someone's calendar to be used as the default form?
or will they have to install it manually?
"Sue Mosher [MVP-Outlook]" wrote:
> To create a new instance of a custom form programmatically, use the Add method on the target folder's Items collection:
> Set newItem = targetFolder.Items.Add("IPM.Post.YourFormName")
> If it's a message form, use the Drafts folder as the target. If the target is a default folder, you can use the Namespace.GetDefaultFolder method to return it as a MAPIFolder object. To create an item in another person's mailbox, use Namespace.GetSharedDefaultFolder to get the MAPIFolder Otherwise, you can use the code at http://www.outlookcode.com/d/code/getfolder.htm to walk the folder hierarchy and return the MAPIFolder corresponding to a given path string.
> See http://www.outlookcode.com/d/launchform.htm for other ideas.
> If you want reminders from non-default folders, upgrade to Outlook 2007 (for folders in your default store) or get the add-in from
> > Sue Mosher
> Author of Configuring Microsoft Outlook 2003
> http://www.turtleflock.com/olconfig/index.htm
> and Microsoft Outlook Programming - Jumpstart for
> Administrators, Power Users, and Developers
> http://www.outlookcode.com/jumpstart.aspx
> "DawnTreader" <DawnTreader> wrote in message news:9171FECB-52AC-47C8-92BF-236DEB041543@microsoft.com...
> > hello
> > i have a number of custom forms i use for different purposes and i need to
> > create a button that will call upon them and then save them in the proper
> > folder.
> > for example, i am a service coordinator, i send technicians to fix things
> > all over and for each trip i need to have a checklist. the form is made, i
> > have a checklist appointment form that i call PreTripChecklist. i want to be
> > able to press a button and have it open that form and then when i finish i
> > need it to be saved in my normal personal calender so that i will get a
> > reminder.
> > that last is the real problem, even though i have created other folders to
> > use those forms in the problem is that i wont get a reminder if the items are
> > stored in another folder other than the main calender folder.
> > if someone can suggest some code, or lead me to a tute or something, it
> > would be appreciated. thanks.
Sue Mosher [MVP]
Sorry, but I don't know that "something" you might be referring to. See
http://www.outlookcode.com/article.aspx?id=27 for info on distributing forms
to other users and http://www.outlookcode.com/article.aspx?ID=39 for
information on making a form the default for a folder. That's a task that
only a folder owner can do, not someone with only delegate rights.
Sue Mosher
news:7BB815F7-6D33-408A-ABB0-A20B29799298@microsoft.com...
> Hello Sue
> > > hello
> > > to
> > > proper
> > > folder.
> > > things
> > > made, i
> > > to be
> > > finish i
> > > reminder.
> > > to
> > > items are
DawnTreader
Hello Sue
sorry, sometimes i write in haste...
this is what i meant by something: Namespace.GetSharedDefaultFolder
can i use "something", code or script like the one i asked about to open a
form and dump it to a specific folder, to install a form in a shared calendar
folder. i can get the user to make me an "owner" of the folder but i dont
know if this is the best way to go about this. i could walk him through the
steps to "publish" a form to his folder, but i dont even fully understand the
way the forms managment dialog works. i think that its the most unintuitive
interface microsoft has.
anyways, those links you posted will probalby help me to come up with a
solution, thanks for your time. :)
> > Sue Mosher
> > Hello Sue
> >> > hello
> >> > to
> >> > proper
> >> > folder.
> >> > things
> >> > made, i
> >> > to be
> >> > finish i
> >> > reminder.
> >> > to
> >> > items are
Sue Mosher [MVP]
Yes, if you want to publish a form to another person's defautl mailbox
folder and IF you have appropriate permission, GetSharedDefaultFolder would
play a role. But that's only a small part of the process. I think a better
solution would be to give the other person a script to run.
Sue Mosher
news:1AF4268B-E29E-40AF-BC8E-E655F0344518@microsoft.com...
> Hello Sue
> calendar
> the
> the
> unintuitive
> > forms
> > > Hello Sue
> > > to
> > >> Add
> > >> another
> > >> string.
> > >> 2007
> > >> > hello
> > >> > need
> > >> > to
> > >> > proper
> > >> > folder.
> > >> > things
> > >> > made, i
> > >> > want
> > >> > to be
> > >> > finish i
> > >> > get a
> > >> > reminder.
> > >> > folders
> > >> > to
> > >> > items are
> > >> > it
