SBS2008 / Exchange with POP3 Connector / Invalid Header Fields -problem
P
Pitti
I have had this problem long time now, and I have been received a very
good trick from "Dan Thompson [MSFT]" / March 2009.
That trick helped me a lot, but didn't give me total fix to the problem.
Problem is that SBS2008 POP3 Connector is trying to deliver emails to
Exchange Server, but fails because those emails are not "standard"
emails. Every email, that is "standard" email, are delivered just fine
to Exchange, but those emails, that aren't "standards" are still staying
on ISP's POP3 Email Server.
Non "standard" email has return path: mailer-daemon - text, and that
makes it non-standard email.
Exchange server has some kind of "filter", which says that this email
cannot be received at all, so it will be rejected. If someone knows how
this "filter" will be disabled, I would be very pleased about quidance.
Here is quote about Dan Thompson technical description:
Also found in this web site
http://www.tech-archive.net/Archive...blic.windows.server.sbs/2009-03/msg00163.html
Exchange will close an SMTP connection after a certain number of
protocol errors (5 by default). (see the MaxProtocolErrors property of
the ReceiveConnector object at:
http://technet.microsoft.com/en-us/library/aa998618.aspx)
When the SBS 2008 pop3connector downloads a message from a POP3 mailbox,
it needs to figure out what the "return path" for the mail should be,
which it does by reading the email's headers. The pop3connector does not
do validation of the header value--it lets Exchange take care of that.
If the header value that the pop3connector chooses is malformed, when it
is sent to the Exchange server (as part of the "MAIL FROM" command),
Exchange will reject it with a 501 error. That counts as a "protocol
error", and therefore is counted against the MaxProtocolErrors limit.
Since the pop3connector was not able to deliver the mail, and does not
know if the mail is safe to delete, it leaves the mail on the POP3 server.
If there are 5 of these messages in your POP3 mailbox, then there will
be 5 "protocol errors" in the pop3connector's SMTP session, which hits
the limit, and Exchange will end the session with a transient error
(4xx). When this happens, the pop3connector recognizes that the error is
transient, and will retry again at the next scheduled download period.
But since those 5 malformed messages are still in the POP3 mailbox, the
same thing will continue to happen, with no "forward progress" being made.
The workaround is to increase the “MaxProtocolErrors” property of the
internal receive connector, which is called “<COMPUTERNAME>\Windows SBS
Fax Sharepoint Receive <COMPUTERNAME>”, and then restart the Exchange
Transport service for the change to take effect (and you’ll have to
restart the pop3connector service, too, since it depends on the Exchange
Transport service). Unfortunately, you can’t set that property from the
Exchange management GUI, so you have to do it from an (elevated)
Exchange Powershell prompt. Here are the instructions:
From an elevated Exchange Management Shell (Exchange Powershell window)
(right click on “Start-->Microsoft Exchange Server 2007-->Exchange
Management Shell” and then choose “Run as administrator”) run the
following Powershell commands:
Set-ReceiveConnector -Identity ($Env:computername + "\Windows SBS Fax
Sharepoint Receive " + $Env:computername) -MaxProtocolErrors 500
Stop-Service pop3connector
Restart-Service -force MSExchangeTransport
Start-Service pop3connector
That will increase the MaxProtocol errors (of the internal receive
connector only) to match the pop3connector’s max emails downloaded per
session. Once you get 500 messages with malformed headers stacked up in
the POP3 mailbox, though, you’ll still have to delete them manually.
Q. Why might you be getting emails with malformed headers?
A. It seems there are some buggy (perhaps deliberately) spam servers out
there. Or it could be non-compliant mail software (like whatever
software generated "Return-Path: <MAILER-DAEMON>" header that started
this thread).
Thanks for advance!
Jani
Hi - short answer to a long post. Do not use the POP connector. Host your
own mail directly. This problem and many many (many many many) others will
go away.
Re: SBS2008 / Exchange with POP3 Connector / Invalid Header Fields- problem
Thanks about very fast answer Lanwench.
This is not my own server, it is my customers server, and main problem
is that they absolutely want to keep that wäy.
So POP3 Connector has to stay there, and we have to use it.
Well, I really need answer to that question, please.
Jani
Re: SBS2008 / Exchange with POP3 Connector / Invalid Header Fields - problem
I know it's tough, but sometimes being a consultant means saying "no."
Especially when there is a better way. They obviously aren't technical
enough to manage their own server, so why are nontechnical people telling
you what transport protocol to use for their mail delivery? Seems to me your
job is to give them good reliable mail delivery, and I've told you how to
achieve that. :)
> Jani
The POP connector is not part of Exchange so you should ask in an SBS 2008
group. And even there you will be advised to drop it. It's to be used for
transitions - not meant to handle your mail forever.
Thanks Lanwench!
Comments between text.
> achieve that. :)
Yes, it's very tough to say what is the best way and best solution. I
have already been trying that many times, no luck.
Quote from Dan Thompson [MSFT]
"If you want to get the malformed mail delivered, you'll have to talk to
some
Exchange experts to see if that's possible--it is Exchange that is rejecting
the mail, not the pop3connector. Maybe try on
microsoft.public.exchange.misc."
So I already started to solve this problem long time ago in SBS-News-Forum.
Complete talk chain is in address:
[invalid link]
Please, check the link, and you get the picture, that I am not the only
one who has this problem.
Please, I really need answer to this solution, please, please.
Jani
Lanwench has given you the answer (a few times now). Even if you have a dynamic IP, you can still use dynamic IP re-director (dyndns etc).
Move off the POP connector and onto Exchange Server!
Duncan
OK. Now is see. Maybe you don't have technical solutions for this, or
you just don't know the answer for this.
I really don't have choise to move off POP connector.
So, I don't need anymore opinion about this situation, I really need
solution that what I can do in Exchange Server, so all "non-standard"
email are downloaded to Exchange Server.
I did get great answer about POP Connector from Dan Thompson [MSFT] in
SBS-News-Group, and that was really great technical answer, no opinion
about this problem.
Dan Thompson [MSFT] quided me to contact Exchange-newsgroup, so that
there I can get the rest solution (because rest of this case is part of
the Exchange), but here we are, just talking about which is the best
solution, the POP Connector or without POP Connector.
If someone has solution, I really, really am grateful for that.
Jani
In article <#C$REoEDKHA.5068@TK2MSFTNGP03.phx.gbl>,
pitti@noemail.noemail says...
Well you are stuck then, with the POP connector bugs. (Try sending a
BCC email to several exhange server users using the POP connector - you
won't like the results).
> about this problem.
The Exchange Server folk will *NOT* be able to help you. The POP
Connector is NOT part of Exchange Server - it is unique to Small
Business Server.
Can you please explain *why* you cannot move to Exchange Server? (and
off the POP Connector?).
Duncan
> Business Server.
Yep. Absolutely true. Pitti, you were misinformed. You could contact SBS
product support services for a paid incident if this is a real need for you.
Your client should of course pay fot that call, since it's their decision to
use this ___ setup.
Why, I cannot move to the REAL Exchange Server solution?
There are many reasons, but most important I guess is my customers email
priority, they need working email solution all the time, every minute.
So, if I move off POP connector, and change to Exchange server solution
without POP Connector, what will happen when I have to make some repair
job to the server, and server is down about two hours.
How my customer will read the emails when server is down?
What will happen if server goes really broken, and I have to make three
days service to the server, and server is down three days?
There is now ISP's POP3 accounts, and if now server goes broken, and I
have to make three days service, my customers can read all the time
their emails in webmail with browser, and even send emails with webmail.
So there won't be any problem with email transfers, even when I will do
that three days service to server.
That is only one reason, and I hope that will be enough, that I can't
really move off POP Connector.
I think that POP Connector works just like it should be, but now
Exchange denies those "non-standards" email.
I know that POP Connector only belongs to Small Business Server, but
should we just now forget that, and focus to Exchange, and how we can
change some settings in Exchange, that it won't denie those
"non-standards" emails?
Thanks Lanwench and Duncan about your opinions
Jani
The answer is that the problem is with the POP connector. I'm not sure how
else to say it.
There are plenty of other ways to deal with downtime (including doing your
scheduled maintenance after hours and having as much hardware redundancy as
possible in your server(s). Check out LiveOffice.com - if you use them for
archiving they've got an email continuity service you can use. Or consider
outsourcing Exchange entirely if they need a better guarantee of uptime than
a small office with a single server can hope for. At any rate, you're
probably SOL with what you're doing now.
Setting up Exchange Server to get your mail is pretty easy, so I'm not
gonna go there unless you ask for help on it.
I think that what you are saying is that you cannot afford downtime on
your server, as mail won't come in.
Well... it will, if your server is down for a reboots etc, or just a
short period of time, due to the way email is sent through servers.
They'll queue and go into "retry" mode, and then still come through.
However, a better way (and Lanwench has already mentioned it) is to use
a backup third party solution, which is very cheap. So that when your
server, Exchange Server (highest priority), is down, it drops to your
backup server, and then you get that mail through when your server is
up.
Such backup server solutions are like:
http://www.dnsmadeeasy.com/
or more specifically...
http://www.dnsmadeeasy.com/s0306/prod/mailbk.html
This provides you three backup servers, some or all of which have
redundancy built in (multiple lines, multiple servers etc).
Problem solved, I hope you'll see. And very cheap, $12.95 USD a year.
Other companies provide the same, but those are the folk I use on all my
clients.
Duncan
First, sorry about long delay in my reply.
Anyway, I can't use those solutions.
But thanks very much your opinions, and solution-possibilities.
I just hope, that Microsoft will repair this, or will give some
possibillity to change behavioir about POP Connector / Exchange / SBS2008.
Thanks, Lanwench and Duncan
I have been reading this thread with interest since we are in the same
situation.
I am a consultant focusing on small businesses. These businesses generally
have no IT support in house and use my company for support as needed.
Sometimes we see the client once/month, sometimes once/week, sometimes only
as needed.
We find that supporting both exchange and groupwise using a pop connector is
fairly durable for this size client, since it will allow, as has been said,
an emergency method to view and respond to emails if something goes wrong in
the email system.
In a perfect world, with support staff on site, email direct to exchange and
groupwise is preferable with a postini or some other backup service storing
your emails in case of an outage. But, in this client set, that does not
work. It could be several days before a diagnosis is found and a fix is
actually implemented in some of these clients. It can be a day or two before
they even notify us if there is an outage of some sort in their email.
To get back to the problem at hand. We have SBS 2008 w/ exchange 2007
using the POP connector and have the same problem with "malformed" emails not
being received and then clogging up the email pathway for our users.
Increasing the error threshold only delays the problem and makes it more
laborious to clean out the POP accounts. Outlook, Eudora, Thunderbird,
Outlook Express can all read these emails. Why can't exchange/Pop connector
allow these emails to be read?
There is obviously a bug or configuration error that should be fixed to
allow this to work properly.
Any ideas are welcome.
More people telling us that the pop connector is the wrong to go are not
much help.
Thanks for listening.
Brad
If you're using the POP connector that comes with SBS, then it's an SBS
component independent of Exchange and so your queries are best directed to
an SBS newsgroup, where the MVPs and others are best informed to help you.
If it's a third-party POP connector, your queries are best directed to the
maker's technical support. In either case, using the POP protocol as a
multiuser mail transport is a great big kludge and any problems you see with
it are undoubtedly related to the fact that this protocol was never intended
to be used in that way.
Ed Crowley MVP
"There are seldom good technological solutions to behavioral problems."
Hello Brad,
I am glad to hear, that you are in same situation, or maybe I shouldn't
be glad, because we are both in trouble with this POP Connector case.
I have been using POP Connector since SBS 2003, and there haven't never
been this big problem, some little problems and always solved with very
small amount work. Usually the fault have been found in Antivirus-product.
I really hope that there is still someone who has "the power and
knowledge solve or repair this".
Maybe someone in Microsoft?
Jani
Thanks Ed about opinion,
If you could read the very first posts about this problem, you could see
that there allready have been long newsgroup posting in SBS Group.
In SBS Group we came to conclusion, that POP Connector is delivering the
email to Exchange Server, but then Exchange denies it totally.
So something have to change in Exchange-settings.
Thanks anyway,
Jani
I read the entire thread, but that doesn't make the POP3 Connector any less
an SBS component.
Ed Crowley MVP
If you open a support ticket with PSS you'll likely find out about that.
Ed Crowley MVP
A Outlook can't remember outlook.com, Exchange password. Using Outlook 0
CWM550 Exchange Plan 1 Using Outlook 3
S Email was migrated from GoDaddy to Microsoft exchange. We lost IMAP ability Exchange Server Administration 1
C Migrate Exchange to Office 365 Using Outlook 2
S client lost 3K contacts when office 365 for mac account deleted from company exchange server Using Outlook 5
C How to fix outlook continuing to prompt fo an Exchange password Using Outlook 0
H Preventing the 'email address fetch from Exchange' crashing email reading code Exchange Server Administration 0
B Strange MAPI/Exchange/IMAP behaviour in OL 2016 under10.0.19044.2006 Using Outlook 0
HarvMan Outlook 365 loses "outlook.com" exchange server settings Using Outlook 1
Z New minimum Outlook for Windows version requirements for Microsoft 365/Exchange Online Using Outlook.com accounts in Outlook 27
J Connect outlook to office365 exchange _without_ signing in office apps Using Outlook 4
J Importing N2K from a different Exchange Server Using Outlook 1
I Exchange 2019 - MICROSOFT-CORP-MSN-AS-BLOCK Exchange Server Administration 0
T Outlook 2010 How to Delete “Orphaned” TO DO? ( Not on Exchange Server) Using Outlook 6
D Microsoft Exchange account - Remote management Using Outlook.com accounts in Outlook 1
