Beginners Design Question
E
escamoteur
before running in the wrong direction I hope you can give me some advice.
I have choosen the Task item as base for my custom item / Inspektors. I will replace the whole form region.
Now several fields of the task item solve almost the same purpose as I would need them in my Application but the names just don't
fit.
Ok, I can rename the Fields description on the Form, but what is with the explorer views. can I also rename the column titles?
Or should I add all fields I need as custom fields??
Best
Tom
You should be able to rename the column titles using the View.XML property.
BUT that won't affect any new views or any views that the user modifies to
add those fields. Those views will still use the standard names. Therefore,
if controlling the names of the columns in all situations is important, you
should consider using custom fields.
Sue Mosher
"escamoteur" wrote:
> Hi,
> fit.
> Best
> Tom
Thanks Sue, this is an important point!
"Sue Mosher [MVP]" <SueMosherMVP> schrieb im Newsbeitrag
news:88E9EE93-D969-44B4-BE4D-D0B4CD7CE3B6@microsoft.com...
> > Sue Mosher
> "escamoteur" wrote:
> > Hi,
> > fit.
>> Best
> > Tom
J Outlook Contacts - Design This Form Outlook VBA and Custom Forms 2
R How to design custom template under message/mail form ! Using Outlook 0
O Outlook Holiday Request Form Design Using Outlook 0
J Form design - how do I insert an automatic date/time field? Using Outlook 2
J 2007 Form Design loads 2003 Form Outlook VBA and Custom Forms 12
D Form Design Outlook VBA and Custom Forms 1
S design buttons in email body Outlook VBA and Custom Forms 1
S Outlook Form Design Outlook VBA and Custom Forms 3
e_a_g_l_e_p_i Question about Outlook 2021 and Gmail Using Outlook 8
G Question marks in messages Using Outlook 2
e_a_g_l_e_p_i Question about calendar Using Outlook 5
e_a_g_l_e_p_i Question about installing my Gmail account on my iPhone but still getting messages downloaded to my desktop Outlook. Using Outlook 3
e_a_g_l_e_p_i Question about reinstalling Outlook 2021 Using Outlook 5
e_a_g_l_e_p_i question about 2-Step Verification with my gmail Using Outlook 0
D Question on removing an alias Using Outlook 1
e_a_g_l_e_p_i A few question before I decide to switch to Pop from imap Using Outlook 9
D.Moore SendAndReceive question Outlook VBA and Custom Forms 2
N Question Using Outlook 8
CWM030 Email Catagorties question Using Outlook 1
MahdeeyaAbdulla Friend's outlook question Using Outlook 1
rerun101 Question about message options Outlook VBA and Custom Forms 4
M Question: Is there a rule that will save email in Windows Explorer Outlook VBA and Custom Forms 3
M Question on address book Using Outlook 1
V Question on pop email Using Outlook 2
D a general question regarding data files Using Outlook 3
R Outlook 2007 - Email Question - POP3 to IMAP Outlook VBA and Custom Forms 11
adaminaus Quick question if i may Using Outlook 4
T Business Projects question BCM (Business Contact Manager) 0
V question about personal and shared calendars Exchange Server Administration 1
C Custom Forms: Question about retaining form information throughout the entire conversation Outlook VBA and Custom Forms 2
D OST question Exchange Server Administration 5
V iCloud question Using Outlook 3
J "Specific word in body" question Using Outlook 1
