1. Here's a thread that needs an answer: Adding Emojis to Outlook's AutoCorrect
virus check engine error in Outlook?
Discussion in 'Using Outlook' started by Qi5TY290dA, Apr 7, 2009.
  1. Qi5TY290dA
    Qi5TY290dA
    Guest
    Error: virus check engine reports an error
  2. neo [mvp outlook]
    neo [mvp outlook]
    Guest
    Microsoft Outlook doesn't come with a antivirus solution. You have a 3rd
    party solution installed that most likely integrates with Outlook that has
    failed.
    "B.Scott" <BScott> wrote in message
    news:043A8F05-E2AE-45C6-901A-F5054EEF1709@microsoft.com...
  3. Qi5TY290dA
    Qi5TY290dA
    Guest
    NEO, thanks for the response. Please review postings in general Q's under
    "virus check engine" for more comments. This is happening to several people
    and it started April 1. Haven't determined common link but I was using MS
    Windows Live OneCare for AV. Deleted and installed Eset NOD 32, went thru
    several other steps to no avail.
    > failed.
  4. neo [mvp outlook]
    neo [mvp outlook]
    Guest
    I couldn't tell by looking at the previous threads if anyone suggested that
    the uninstall of Windows Live OneCare might not be complete. Perhaps
    running this tool might help.
    http://download.microsoft.com/download/4/c/b/4cb845e7-1076-437b-852a-7842a8ab13c8/OneCareCleanUp.exe
    news:6440D8D2-3264-4B33-85A0-429200EA52FB@microsoft.com...
    > people
    > > has
    > > failed.
  5. Qi5TY290dA
    Qi5TY290dA
    Guest
    Neo, Thanks. I ran the utility and it didn't work. The People at HP have been
    unable to help either. Everyone seems to favor wiping the hard drive and
    starting over...
    > > people
    > >> has
    > >> failed.
  6. neo [mvp outlook]
    neo [mvp outlook]
    Guest
    Seems a bit extreme...
    If you can, open the registry and take a peek at this location:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Exchange\Client\Extensions
    What do you have listed here?
    The other section I am curious about is:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Office\Outlook\Addins
    The only other harmless thing I can think to try is to delete a file named
    extend.dat. This file would be located under \documents and
    settings\<userid>\Local Settings\Application Data\Microsoft\Outlook. This
    file will be rebuilt from the registry data at:
    Note: I'm assuming you are running a 32bit operating system like Windows
    2000/XP.
    news:0A8C4AA3-E819-4F24-B533-7948E1F869A0@microsoft.com...
    > been
    > starting over...
    > > that
    > > > under
    > > > people
    > > > MS
    > > > thru
    > > >> 3rd
    > > >> has
    > > >> failed.
  7. Qi4gU2NvdHQ
    Qi4gU2NvdHQ
    Guest
    Guprup in India provided the solution: Download the latest version of Outlook
    Connector. Uninstall old version, install new version (3/27/2009 ver. 12.1)
    and preso chango! It works...
    > 2000/XP.
    > > been
    > > starting over...
    > >> that
    > >> > under
    > >> > people
    > >> > MS
    > >> > thru
    > >> >> 3rd
    > >> >> has
    > >> >> failed.
Loading...
Share This Page
