Outlook macro help please
  • Thread starter Victor Delta
  • Start date Views 6,079
V
Victor Delta
"Victor Delta" <none@nospam.com> wrote in message
news:%23TRmogYqJHA.200@TK2MSFTNGP05.phx.gbl...
> news:OKENscNqJHA.5832@TK2MSFTNGP06.phx.gbl...
> > "PaulD" <nospam> wrote in message
> > news:%23cCpZtJqJHA.1172@TK2MSFTNGP05.phx.gbl...
> >> Victor,
> >> You were correct to change 'Dim WshNetwork As Object', that should work.
> >> Since you could follow my directions before, I would recommened you try
> >> this: set a break point on the line
> >> For i = mySelection.Count To 1 Step -1
> >> in the PrintGreen sub and then run the code. You should be able to
> >> hover
> >> over the strDefault variable to see if it was set, then open your
> >> printers
> >> and faxes window and see if the default printer was switched. To make
> >> sure
> >> I have the same code as you I copied the code from your post below into
> >> a
> >> new module and ran it to make sure it worked. I got an error saying it
> >> couldn't find the printer "GREENPRINT" which is good since I don't have
> >> that
> >> printer. I changed it to a network printer I do have (CutePDF) and it
> >> worked. Investigae some more and post back with your results
> >> Paul D
>> Paul
>> Thanks. This is most odd. Followed your instructions and sure enough,
> > using
> > the break point, the default printer does change to Green Print and then
> > changes back. However, the print out still seems to go through to the
> > wrong
> > printer, although on a couple of occasions when using Step into (F8) I
> > got
> > it to go to Green Print. I've been trying again and for the last 10
> > minutes
> > it will only go to the wrong printer!
>> I'll do some more experimentation but not quite sure why it should be so
> > inconsistent! Any ideas? We're so nearly there...
> Have done some more experimentation and believe I have now found the
> problem - and it's very interesting.
> To aid clarity lets call the two printers Printer A (normal default) and
> Printer Green. Once Outlook is open, if you change the default printer
> (either manually or via your macro with the break point on the "For i =
> ..." line) if you hover over the Print button at the top of any email, you
> will see the name of the new printer (in my case Printer Green). This
> looks very promising...
> However, there's a big gotcha! If you now open the Outlook Print dialogue
> box (Ctrl +P), although you will see the little black tick against the
> name of the new default printer, the original printer (Printer A) is
> actually still selected (highlighted in blue). So if you now print, either
> by clicking the button or running the second part of your code, the email
> goes to the original printer. I guess this is what Ken was telling us all
> along!
> If only there were a way to 'refresh' the printer selection to the new
> default printer it would work but, so far, I haven't thought of one. Any
> ideas?
> The only surprise now is that you've managed to make it work at your end.
> I've been using Windows XP with Outlook XP/2002 and, on another machine,
> Outlook 2003. Same as you?
> V
Just another thought... If it's really not going to be possible to
automatically send emails to Printer Green, then a poor 'second best'
solution would be to only print the first page. From googling on this, I
gather there is no simple way to do this either, unless someone knows
differently...?
V
P
PaulD
Im running Windows XP with Outlook 2003. My print dialog only shows the
active printer in a pull down list that is disabled so the printer can't be
changed. I do not see my others printers in the dialog or any black tick
marks. As Ken stated earlier, since Outlook doesn't offer any control over
printing, I doubt it would have a refresh option available but I'll see if I
can find anything.
Paul D
Paul D
: "Victor Delta" <none@nospam.com> wrote in message
: news:OKENscNqJHA.5832@TK2MSFTNGP06.phx.gbl...
: > "PaulD" <nospam> wrote in message
: > news:%23cCpZtJqJHA.1172@TK2MSFTNGP05.phx.gbl...
: >> Victor,
: >> You were correct to change 'Dim WshNetwork As Object', that should
work.
: >> Since you could follow my directions before, I would recommened you try
: >> this: set a break point on the line
: >> For i = mySelection.Count To 1 Step -1
: >> in the PrintGreen sub and then run the code. You should be able to
hover
: >> over the strDefault variable to see if it was set, then open your
: >> printers
: >> and faxes window and see if the default printer was switched. To make
: >> sure
: >> I have the same code as you I copied the code from your post below into
a
: >> new module and ran it to make sure it worked. I got an error saying it
: >> couldn't find the printer "GREENPRINT" which is good since I don't have
: >> that
: >> printer. I changed it to a network printer I do have (CutePDF) and it
: >> worked. Investigae some more and post back with your results
: >> Paul D
: > Paul
: > Thanks. This is most odd. Followed your instructions and sure enough,
: > using
: > the break point, the default printer does change to Green Print and then
: > changes back. However, the print out still seems to go through to the
: > wrong
: > printer, although on a couple of occasions when using Step into (F8) I
got
: > it to go to Green Print. I've been trying again and for the last 10
: > minutes
: > it will only go to the wrong printer!
: > I'll do some more experimentation but not quite sure why it should be so
: > inconsistent! Any ideas? We're so nearly there...
: Have done some more experimentation and believe I have now found the
: problem - and it's very interesting.
: To aid clarity lets call the two printers Printer A (normal default) and
: Printer Green. Once Outlook is open, if you change the default printer
: (either manually or via your macro with the break point on the "For i =
: line) if you hover over the Print button at the top of any email, you will
: see the name of the new printer (in my case Printer Green). This looks
very
: promising...
: However, there's a big gotcha! If you now open the Outlook Print dialogue
: box (Ctrl +P), although you will see the little black tick against the
name
: of the new default printer, the original printer (Printer A) is actually
: still selected (highlighted in blue). So if you now print, either by
: clicking the button or running the second part of your code, the email
goes
: to the original printer. I guess this is what Ken was telling us all
along!
: If only there were a way to 'refresh' the printer selection to the new
: default printer it would work but, so far, I haven't thought of one. Any
: ideas?
: The only surprise now is that you've managed to make it work at your end.
: I've been using Windows XP with Outlook XP/2002 and, on another machine,
: Outlook 2003. Same as you?
: V
V
Victor Delta
news:OoxUBs7qJHA.4364@TK2MSFTNGP04.phx.gbl...
> be
> over
> I
> can find anything.
> Paul D
Try opening an HTML email and then pressing Ctrl + P - then you'll see the
print dialogue box I'm talking about (Outlook has different ones for plain
text and HTML emails).
When I click Ctrl + P with the same email selected but closed instead of
open, I get the same dialogue box that you are talking about and curiously
this seems to have the effect of refreshing the printer as if I then open
the email and press Ctrl + P, the new default printer is selected...
I wonder if this gives us a way to solve the refresh problem i.e. close the
email, open print dialogue, cancel, open email, and then print...!? I don't
know if this is possible?
We're so very close to a solution...
Regards,
V
P
PaulD
For the record I never print emails while they are open... for that matter I
never open them since I keep a preview window open below, so when I select
an email, I can see it in the preview. All of the test printing I did using
the macro was from selected email in the main window, not open emails.
Paul D
news:Oko$1U9qJHA.2424@TK2MSFTNGP06.phx.gbl...
: "PaulD" <nospam> wrote in message
: news:OoxUBs7qJHA.4364@TK2MSFTNGP04.phx.gbl...
: > Im running Windows XP with Outlook 2003. My print dialog only shows the
: > active printer in a pull down list that is disabled so the printer can't
: > be
: > changed. I do not see my others printers in the dialog or any black
tick
: > marks. As Ken stated earlier, since Outlook doesn't offer any control
: > over
: > printing, I doubt it would have a refresh option available but I'll see
if
: > I
: > can find anything.
: > Paul D
: Try opening an HTML email and then pressing Ctrl + P - then you'll see the
: print dialogue box I'm talking about (Outlook has different ones for plain
: text and HTML emails).
: When I click Ctrl + P with the same email selected but closed instead of
: open, I get the same dialogue box that you are talking about and curiously
: this seems to have the effect of refreshing the printer as if I then open
: the email and press Ctrl + P, the new default printer is selected...
: I wonder if this gives us a way to solve the refresh problem i.e. close
the
: email, open print dialogue, cancel, open email, and then print...!? I
don't
: know if this is possible?
: We're so very close to a solution...
: Regards,
: V
