RE: Error: BCM Home Tab - Opportunity Funnel Chart issue?
#1
I am having the same issue now. I have cleared the cache files and installed
all applicable service packs, compatibility packs, and updates. Any othe
suggestions?
"Arun (sreearun)" wrote:
> When I click on the home tab of Outlook BCM, it throws up an error "Business
> contact manager could not complete your last action or actions. Please try
> again."
> I also see an 'X' in the "Opportunity Funnel Chart" section, and I believe
> it has something to do with it. I tried to display another chart (pipeline)
> and it threw the same error!
> Appreciate any help
Raul Thomas
#2
Hi Folks
Can you give me some additional detail on the steps to repro the issue ?
Also are we all running Business contact manager with SP 2?
Regards
Rahul Thomas [MSFT]
The posting is provided "AS IS" with no warranties and confers no rights.
https://blogs.msdn.com/rathomas
"bg" <bg> wrote in message
news:614B38A2-3295-4060-AEEF-69CA2ACED9E6@microsoft.com...
> installed
> suggestions?
> > "Business
> > try
> > again."
> > believe
> > (pipeline)
>> Appreciate any help
Arun (sreearun)
#3
Hello Raul,
Yes. I am running BCM SP2. I have Outlook 2007. Please let me know what you
are specifically looking for and I should be able to give you.
Things were working normally and from one day, it didn't.
1. Click BCM home in the outlook toolbar
2. It should usually take you to the first tab (but now takes me to the
second tab)
3. When I navigate back to the first tab it throws that error - Rather
wherever the chart should be drawn it apparently is throwing that error.
Thank You,
Arun
"Raul Thomas" wrote:
> Hi Folks
> > Regards
> Rahul Thomas [MSFT]
> > installed
> > suggestions?
> >> "Business
> >> try
> >> again."
> >> believe
> >> (pipeline)
> >> Appreciate any help
Raul Thomas
#4
Hi Arun
Thanks for your response .
Can you send me a screen shot of the error ?
I would also want you to attempt the following steps :
Enable logging in Business Contact manager repro the issue and share the log
Also can you back up and delete the Business Solution eCRM key under
HKEY_USER >Software > Microsoft
Note : If the files are large send the response only to me
Regards
Rahul Thomas [MSFT]
"Arun (sreearun)" <Arun (sreearun)> wrote in
message news:B2340991-07E9-4317-9EBC-1AD2E6E01482@microsoft.com...
> Hello Raul,
> you
> second tab)
> Thank You,
> Arun
> > Hi Folks
>> > > Regards
>> Rahul Thomas [MSFT]
> > rights.
> > > installed
> > > othe
> > > suggestions?
> > >> "Business
> > >> try
> > >> again."
> > >> believe
> > >> (pipeline)
>> >> Appreciate any help
