RE: Outlook 2007 Appointment Invitation has wrong sender
P
Patrick Lyman
I can reproduce this also, it is a major problem - has been an issue since
Outlook 2003.
Can Microsoft provide a resolution or indication of a workaround other than
to constantly switch my "default" email account to send invitations (which is
what I do today)?
"Waquar" wrote:
> Hi JC
> its been long since you posted this issue, now I am facing the same, but
> have found no answer to it. Can you please guide me if you have, OR anyone
> has found an answer to it.
> Regards
> Waquar
> "JC" wrote:
> > I scheduled an appointment in Outlook 2007 (12.0.6300.5000) and sent the
> > invitation from another account (POP/SMTP account) in my Outlook profile.
> > The invitation said "This message will be sent via correct-account@test.com".
> > When the invitation was received by the recipient, it came from the Exchange
> > account not from the POP/SMTP account that I specified.
> > I searched the KB, but couldn't find any reports of this. Can anyone
> > reproduce this?
> > Thanks,
> > JC
> > --------------> > This post is a suggestion for Microsoft, and Microsoft responds to the
> > suggestions with the most votes. To vote for this suggestion, click the "I
> > Agree" button in the message pane. If you do not see the button, follow this
> > link to open the suggestion in the Microsoft Web-based Newsreader and then
> > click "I Agree" in the message pane.
> > ?mid=cfd9b01c-b997-4a3c-9ba5-e6cc6163e062&dg=microsoft.public.outlook.general
Do you have SP2 installed? It fixes a number of issues although I don't know
if this is one. I can't repro it with an exchange and outlook connector
account.
"Patrick Lyman" <Patrick Lyman> wrote in message
news:C2D0765C-FBEC-4B09-B0DC-9D26D3D368DA@microsoft.com...
> Outlook 2003.
> than
> is
> what I do today)?
> "Waquar" wrote:
> > Hi JC
> > anyone
>> Regards
> > Waquar
> > > the
> > > profile.
> > > Exchange
> > > reproduce this?
> >> > Thanks,
> > > JC
> >>>> > --------------> > > This post is a suggestion for Microsoft, and Microsoft responds to the
> > > "I
> > > this
> > > then
C
ClimberBear
I've the same Issue
* Office 2003 Pro
* Vista Home Premium
Any idea or workaround?
> account.
> > Outlook 2003.
> > than
> > is
> > what I do today)?
> > "Waquar" wrote:
> >> Hi JC
> >> anyone
> >> Regards
> >> Waquar
> >> > the
> >> > profile.
> >> > Exchange
> >> > reproduce this?
> >> >> > Thanks,
> >> > JC
> >> >> >> >> > --------------> >> > This post is a suggestion for Microsoft, and Microsoft responds to the
> >> > "I
> >> > this
> >> > then
Andres Perez
Anyone with a solution for this issue?, i´m still experiencing the same. i
have two POP3 accounts when i schedule a new appointment and select the
account i want to use to send the invitation outlook send it using the
default email account in all cases, I discover switching the default account
will make outlook to send it to the account you selected as default despite
your selection on the meeting scheduling UI, anyway this is very annoying and
you end up messing things around and sending invitation with the wrong
account,
I´m using Outlook 2007 (12.0.6514.5000) SP2 MSO 12.0.6425.1000)
Windows Vista Home Premium Build 6002 SP2
C
Claudio
Hi, I had the same trouble, but I could fix it in an easy way I hope can help
You too.
Go to the owner mailbox Tools/Options/Delegates and check proper settings
here.
In my case, an old user was still inside and messed up the sender email
address. Once I removed it and placed the proper user I need to delegate, the
trouble was fixed.
Hope it helps, cheers.
> account,
> Thank you!
