Auto processing of incoming mail
John
1. How can I check via code every incoming email, check if attachment of a
specific type (file extension) is present and if so save the attachment to a
folder?
2. Where can I find some pointers on writing my first Outlook Add-in?
Many Thanks
Regards
See my answer in the other group, please do not multipost.
Outlookcode.com has various samples of addins, as do the downloads at the
Office developer Web site. Some of us also have templates available but to
recommend any we'd need to know the Outlook version and VS version you
intend to support and to use.
"John" <info@nospam.infovis.co.uk> wrote in message
news:eqIEvmOJKHA.4232@TK2MSFTNGP02.phx.gbl...
> Hi
> a
> folder?
> Many Thanks
> Regards
J Auto processing of incoming mail Outlook VBA and Custom Forms 1
P Email address auto-completes work fine on laptop, but no longer on desktop Using Outlook 2
Nufc1980 Outlook "Please treat this as private label" auto added to some emails - Help. Using Outlook 3
F Auto changing email subject line in bulk Using Outlook 2
