CCR ReplayQueueLength constantly growing
  • Thread starter Thomas Stensitzki
  • Start date Views 3,770
Thomas Stensitzki
in an Exchange Server 2007 SP1 RU9 CCR Cluster on Windows Server 2008 I do
have a passive copy of a mailbox database where the ReplayQueueLength is
constantly growing. The CopyQueueLength remains 0.
The Copy Status of the SG is: Healthy
When I try to update the passive copy using Update-StorageGroupCopy the
following error occurs:
Storage group MAIL00\12-Move failed to seed at E:\Mailboxes\12-Move. Reason:
Error returned from an ESE function call (0xc7ff1004), error code (0x6)..
The PowerShell prompt and the EMC have been started using "Run as
Administrator". The used account does have all appropriate rights (works fine
on Windows Server 2003 within the same domain)
Does anyone have a clue?
Thomas Stensitzki
MCITP, MCTS, MCSA, MCSA:Messaging
O
Oliver Moazzezi [MVP]
Hi Thomas,
You may need to suspend and then resume.
Oliver
Andy David {MVP}
On Tue, 25 Aug 2009 07:37:01 -0700, Thomas Stensitzki
<ThomasStensitzki> wrote:
> Hi,
It may re-seed time. Can you get a backup?
Thomas Stensitzki
Hi Oliver,
"Oliver Moazzezi [MVP]" wrote:
> Hi Thomas,
> Oliver
When I used suspend and resume, the SG stopped replicating with an error.
But I found the solution:
I've found some articles about the mentioned error number. Some articles
mentioned the Windows Server 2008 Firewall. After activating the setting to
display a pop-up when a connection is being blocked, the EMC showed up. After
unblocking the EMC in the Windows Firewall updating the SG worked fine. The
Powershell itself is being added to the Firewall by the Exchange setup, the
MMC is not. As our clients admins want to use the EMC I had to add the EMC to
the rule set.
Regards,
Thomas
Thomas Stensitzki
Thomas Stensitzki
Hi Andy,
The error occured during reseeding. Backup worked fine with BE 12.5.
But I found the solution. Take a look at my answer to Olivier.
Regards,
Thomas
Thomas Stensitzki
Andy David {MVP}
On Sat, 29 Aug 2009 06:52:01 -0700, Thomas Stensitzki
> Hi Andy,
Groovy. I think I missed the part that this was part of a new install,
or at least it seems so. Glad you got it working.
> Regards,
> Thomas
E
Ed Crowley [MVP]
Groovy?
Ed Crowley MVP
"There are seldom good technological solutions to behavioral problems."
"Andy David {MVP}" <adavid@pleasekeepinngcheesebucket.com> wrote in message
news:tdri95lromnbmel45tvfjd7f963ts4tie1@4ax.com...
> >Hi Andy,
>>Regards,
> >Thomas
Andy David {MVP}
On Sat, 29 Aug 2009 16:35:23 -0700, "Ed Crowley [MVP]"
<curspice@nospam.net> wrote:
> Groovy?
Parents.harumpph.
J Exchange Server Questions 1
S Exchange Server Questions 3
J Exchange Server Questions 2
J Exchange Server Questions 11
H Exchange Server Questions 3
