Mapping from excel to BCM
P
paminmi
I have just started using BCM. I have a large contact list in excel that I
want to import into BCM, but want to make sure that things map correctly. If
I want the "lead" box in BCM to be checked on all of these entries, can I
create a field on my excel spreadsheet that I can map to the "lead" box in
BCM?
I found my answer to this question. Thought it may help other users. I
created a Lead column in my excel spreadsheet. Then for each record I
entered the value "1" under the column. When I imported my spreadsheet, I
mapped Lead to Lead, and tada! The lead box was checked when I opened the
contacts in BCM.
Also, since I wanted the "Active" box to be unchecked, I had to create an
"Active" column in excel and enter the value "0" for each entry. When it
imported, the Active box was unchecked. Hope this helps!
> BCM?
M Setting mapping field default BCM (Business Contact Manager) 5
T field mapping errors during import BCM (Business Contact Manager) 1
L Error when exporting Sent Mail to Excel Outlook VBA and Custom Forms 6
P OT: Need website like this one, but for Excel Using Outlook 0
D Cannot populate certain UserProperties in Outlook from Excel Outlook VBA and Custom Forms 2
N Extract Outlook emails to excel Outlook VBA and Custom Forms 2
C Pull Outlook shared calendars items from Excel Outlook VBA and Custom Forms 4
S How to export urls from email to excel and check the status of the url ? Using Outlook 5
C Trying to populate an appointment ComboBox from Excel Outlook VBA and Custom Forms 2
E Accessing shared outlook folder doesn't work since switch to new outlook/excel Outlook VBA and Custom Forms 11
E Copying the whole e-mail body into excel Outlook VBA and Custom Forms 0
K Update Appointment category when changed in Excel Using Outlook 3
D Paste Excel table into Outlook message Outlook VBA and Custom Forms 6
D Retrieving Tables from outlook to excel Using Outlook 14
nathandavies Email Details to Excel & Save as .MSG on one macro - combination of 2 macros Outlook VBA and Custom Forms 3
T Outlook Calendar 2016 import Excel Using Outlook 1
N Lookup Value From Excel and Reply With Matching Value Using Outlook 0
D send email from Excel using outlook template Outlook VBA and Custom Forms 3
Diane Poremsky Importing Lists from Excel to Outlook Using Outlook 0
N Paste content to Excel when .txt file (attachment) is opened Outlook VBA and Custom Forms 1
M Creating Outlook Appointments from Excel Cells Outlook VBA and Custom Forms 1
M Linking Excel Cell to Shared Contacts Outlook VBA and Custom Forms 7
R Exporting Excel data to Outlook 2016 Calendar Outlook VBA and Custom Forms 20
