ComboBox (using Commas)
srm
I'm using O2003, creating a custom form, using the combo box control.
I want to add multiple values but within those values I want to use
commas. For example
This is value number 1, and it has a comma
This is value number 2, and it has a comma
However, Outlook thinks the comma is a new entry and it lists the
items as follows:
and it has a comma
and it has a comma
It there a way to add entry using a comma as part of the entry?
Shawn
Sue Mosher [MVP]
You would need to use code in the form's Item_Open event handler. See
http://www.outlookcode.com/article.aspx?ID=32 for a sample form.
Sue Mosher
"srm" <srm@primatech.com> wrote in message
news:3d96ff92-e3e6-432b-8ab5-5172ccd0ae74@g1g2000vbr.googlegroups.com...
> commas. For example
> items as follows:
> and it has a comma
> and it has a comma
> Thank you.
> Shawn
srm
On Sep 1, 11:57 am, "Sue Mosher [MVP]" <sue...@turtleflock.com> wrote:
> You would need to use code in the form's Item_Open event handler. Seehttp://www.outlookcode.com/article.aspx?ID=32for a sample form.
> > Sue Mosher
> "srm" <s...@primatech.com> wrote in message
> > commas. For example
> > items as follows:
> > and it has a comma
> > and it has a comma
> > Thank you.
> > Shawn
Sue:
Thank you. I don't want to take too much of your time. I got this to
appear on a test form in the "General" and "P.2" tab, but not my
custom form "General" or "P.2" tab. I see the drop down, but no data.
I' think I'm past my capability of coding at this point. I still
cannot get it to accept the commas and I'm not a big coder. Am I close
or over my head at this point and need to look at other options?
Function Item_Open()
' Sets the name of page on the form (General)
Set FormPage = Item.GetInspector.ModifiedFormPages("General")
' Sets Control to a combo box called ComboBox1.
Set Control = FormPage.Controls("ComboBox1")
' Assign values to the combo box.
Control.PossibleValues = "Blue;Green;Red;Yellow"
End Function
Shawn
Sue Mosher [MVP]
You should never use PossibleValues in code. Did you look at the sample form
on the I suggested? It shows exactly how to load rows into a list box or
combo box from a delimited string.
Sue Mosher
news:99794827-deb2-4e7f-a664-05f4418a0974@o13g2000vbl.googlegroups.com...
> > commas. For example
> > items as follows:
> > and it has a comma
> > and it has a comma
> > Thank you.
> > Shawn
Sue:
End Function
Shawn
srm
> > Sue Mosher
> > Seehttp://www.outlookcode.com/article.aspx?ID=32fora sample form.
> > > commas. For example
> > > items as follows:
> > > and it has a comma
> > > and it has a comma
> > > Thank you.
> > > Shawn
> Sue:
> End Function
> Shawn
Sue:
Thank you. I will check the page again. I appreciate your time.
Shawn
