How to determine if message will be encrypted on Send
  • Thread starter sf0
  • Start date Views 1,417
sf0
I'm trying to remove certain UserProperties when messages are sent. All
is well unless Outlook cancels the Send event when it has problems
encrypting (see Outlook's message further below). In that case, the
user has 2 options: "Send Unencrypted" or "Cancel". My problem is I
cannot determine which option the user selected.
The significance of these options is as follows: if the user selects
"Cancel", the UserProperties which were removed in MailItem_Send must
be restored (I have a solution for this in the Activate event); if the
user selects "Send Unencrypted", I don't want to do anything.
The only indication I have that the user has opted to "Send
Unencrypted" is the 2003 Word editor throws an error when I attempt to
access the currentItem.UserProperties. No error is thrown in 2003
default editor or 2007.
Is there a way to determine which button the user clicked?
Alternatively, is there a way to determine if Outlook intends to
encrypt the message or not? Or should I remove these UserProperties
somewhere other than MailItem_Send?
FYI, I don't have access to Redemption or any other 3rd party
software.
Outlook's message:
Microsoft Outlook had problems encrypting this message because the
following recipients had missing or invalid certificates, or
conflicting or
unsupported encryption capabilities...
Thank you in advance for your help!
sf0
sf0
Alternatively, is there a way to validate the certificates of the sender
and recipients? If so, I could cancel the MailItem_Send event and not
have to worry about restoring my currentItem to it's pre-send State.
> software.
> Outlook's message:
> conflicting or
sf0
