Export in 2007 not working
RGFuTA
I am trying to export my contacts to a csv file. I click on
File/export/export to a file and then "next", but nothing happens. Any ideas?
Brandon
You would need to be more specific about the options chosen. For example,
be sure you're using the Windows CSV and not DOS.
Brandon
http://www.PresentationsDirect.com
"DanL" <DanL> wrote in message
news:8CFD106E-269C-43D5-A96F-9A9C1EEBDAFD@microsoft.com...
> ideas?
RGFuTA
I didn't make myself clear, my apologies. I am referencing the menu commands
I am clicking on in the above question. Said differently, when I click on the
"next' button (under the menu "File/Export/Exportto a file"), no action
results. The menu just stays there with no apparent action taking place. Hope
that clarifies ... and thank you for your response!
> > Brandon
> > ideas?
Justin
I ran into this same issue and was able to resolve it fairly painlessly. Go
into Add/Remove and select Change on Office 2007. Expand Outlook and set
Importer/Exporters to Not Available and click Install. Allow the install
process to complete then go back into Add/Remove and set Imports/Exports to
Run on First Use. Go back into Outlook and try the Export again. I had an
install start as soon as I clicked File – Import/Export and another start as
soon as I clicked next after selecting the first Import/Export option.
DanL
Justin:
As simple as that!!! It worked to perfection and I can't tell you how much I
appreciate your direction on this. It was, in fact, painless and it worked.
Thank you for your help and your involvement in helping us dummies.
