Append text to (formatted) body of Reply
Mark Parent
My VBA code is properly finding and opening emails that I want to reply to,
but the body of these messages is formatted somewhat with a table and some
bordering.
I want to append some text to the bottom of this outgoing reply via my code,
but using objItm.Body = objItm.Body & chr(13) & newstring
seems to be removing all the formatting. I can send the reply (with its
formatting) just fine when I manually add text to the bottom, but I can't
seem to replicate this through my code. If can understand the line above
concatenating newstring might be forcing the body to text; is there a coding
way to position the cursor after the existing text and add text without
affecting the existing formatting?
You woudl need to set the HTMLBody propretty instead of Body.
Read the old value of HTMLBody, find the position of the "</body", inset
your own value just before that, set the new value of HTMLBody
Dmitry Streblechenko (MVP)
"Mark Parent" <MarkParent> wrote in message
news:42CCACDB-6612-4201-BE11-76D32AD2B6DA@microsoft.com...
> to,
> bordering.
> code,
> coding
Thank You Dmitry... That's put me on the right track, and I've been able to
produce a much better looking outgoing email.
On a side note, let me thank all of the responders to these discussions...
This board is an incredibly practical resource!
> > to,
> > bordering.
> > code,
> > coding
D How to append text to a redirected message Using Outlook 3
K Append subjectline based on number Using Outlook 4
L Transport rule - append disclaimer Exchange Server Administration 1
C Save outlook attachments and rename/append files with identifier from subject line Outlook VBA and Custom Forms 3
H PRF with OverwriteProfile=Append Is overwriting other settings Using Outlook 2
D Delete selected text in outgoing email body Outlook VBA and Custom Forms 0
O Replace hard returns with soft returns on selected text and button to QAT Using Outlook 5
J Outlook 365 Emails showing as links and text only Using Outlook 4
J Text icon in Quick Access toolbar ? Using Outlook 2
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
S Unable to extract text from an Outlook email message Using Outlook 2
T Original email text not shown when replying or forwarding the email. Using Outlook 9
S Outlook to check for specific text Outlook VBA and Custom Forms 3
B Paste formatted text (bold, underlined and in quotes) Outlook VBA and Custom Forms 1
N Is there an Outlook tool to normalize text for entries that are in ALL CAPS? Using Outlook 2
