Migratiom from win 2k3 to 2k8 and Ex2k3 to Ex2k7.
  • Thread starter Jaywant
  • Start date Views 1,399
Jaywant
Hi All,
I need to upgrade my exchange and windows 2003 Environment Exchange 2k7 and
windows 2008. Kindly suggest me best Plan.
I have Exchange 2003 in Clustered environment. ( for mailbox server rol 2
active nodes 1 passive node). I have 2 frontend servers.
All are Windows 2k3-R2 Sp2.
Also I have one Exchange 2000 server for instant Messanger.
One Public folder server.
Only Mailbox servers are Clustered.
Kindly suggeste me best plan for migration to win 2k8 and ex2k7.
Thanks in advance.
Jaywant Kamble.
O
Oliver Moazzezi [MVP]
Hi there,
You cannot inplace upgrade from Exchange 2003 to 2007, so it's all new x64
hardware.
Your only plan is to build your Windows 2008 Servers (leave forest
functional level as 2003, upgrading to 2008 is not supported/tested with
Exchange 2003), and then Schema and Domain prep your Org for Exchange 2007
SP1 (SP1 is supported for Windows 2008).
You are then ready to install your first Exchange 2007 Server.
What are your deployment and high availability options for Exchange 2007?
Have you for that far in your design yet? I presume you will have HA as your
already do in your 2003 environment.
Oliver
Jaywant
Hi Oliver,
My cuurent env. is
1. Front End servers - 2
2. Mailbox Servers - 2 (Clustered- Active, Active, Passive)
3. Public folder server - 1
4. Instant messaging Server - 1
I have 3 SG per Mailbox servers and 2 mailstore per SG.
What I am planning is
1. Two server with CAS and HUB role installed in NLB.
2. Two Mailbox server roles with CCR H/A (Total 4 servers for mailbox).
Steps I willbe performing.
1. I will upgrade My Root Domain to Win 2008.
2. Install and configure windows Cluster service on win 2008 server whil
will be CCR.
3. Then I will Install Exchange server with CAS/HUB as my first Exchage 2007
on brand new servers.
4. Install and configure CCR roles on Windows 2008 servers on which I will
configure CCR.
5. Finally move resources from Exchange 2003 to 2007.
Kindly suggest me if anything is missing.
Also could you giude me how should I migrate RUS, GAL, and recipients
policies from Exchange 2003 to 2007.
Thakns
1. Updgarde root Domain to Win 2008.
2. Install New Exchange
Jaywant Kamble.
"Oliver Moazzezi [MVP]" wrote:
> Hi there,
> hardware.
> Oliver
E
Ed Crowley [MVP]
You should build the HT+CAS servers before the CCR cluster. One reason is
that one of the HT+CAS servers should host the cluster's file share witness.
So you want to change the order to 1, 3, 2, 4, 5.
Ed Crowley MVP
"There are seldom good technological solutions to behavioral problems."
"Jaywant" <Jaywant> wrote in message
news:82938A8E-2C0D-4D6D-8174-1C71A7829524@microsoft.com...
> Hi Oliver,
> My cuurent env. is
> will be CCR.
> 2007
> configure CCR.
> Thakns
> > Jaywant Kamble.
> > Hi there,
> > x64
> > hardware.
> > 2007
> > your
>> Oliver
E
Ed Crowley [MVP]
Also, for step #5, replicate public folders ahead of moving mailboxes.
Ed Crowley MVP
> Hi Oliver,
> My cuurent env. is
> will be CCR.
> 2007
> configure CCR.
> Thakns
> > Jaywant Kamble.
> > Hi there,
> > x64
> > hardware.
> > 2007
> > your
>> Oliver
Jaywant
Can you guide me what will happen with RUS and policies.
Or what step I should take for policies and RUS
Jaywant Kamble.
> > Ed Crowley MVP
> > Hi Oliver,
> > My cuurent env. is
> > will be CCR.
> > 2007
> > configure CCR.
> > Thakns
> > > > Jaywant Kamble.
> >> Hi there,
> >> x64
> >> hardware.
> >> 2007
> >> your
> >> Oliver
E
Ed Crowley [MVP]
If you're asking about recipient policies, they get translated into both
accepted domains and e-mail address policies. You may need to update them
after installing Exchange 2007. You can delete the recipient update
services once you make the decision to stop creating recipients on Exchange
2003, or you can wait until just before removing the last Exchange 2003
server.
Ed Crowley MVP
news:6E10C33F-73AC-4E77-97D9-65C1DB76578F@microsoft.com...
> > Jaywant Kamble.
> > > > Ed Crowley MVP
> > > Hi Oliver,
> >>> > My cuurent env. is
> > > whil
> > > will be CCR.
> > > 2007
> > > will
> > > configure CCR.
> >> > Thakns
> >>>>> > > > > Jaywant Kamble.
> >> >> Hi there,
> > >> x64
> > >> hardware.
> > >> with
> > >> 2007
> > >> 2007?
> > >> as
> > >> your
>> >> Oliver
