Upgrade to 2007, lost 'Accounts' info
ArmandoA
I upgraded from MS Office 2003 to MS Office 2007. Now I can't find all the
info I had in 2003 in my "Accounts" section. This included timekeeping info,
billing of clients, etc. When I click on "Business Contact Manager," it tells
me the MAPI couldn't load the file "irisms.dll", and I can't find that file
either. HELP!
Still looking for help on this one.... Anyone out there? Thanks.
> either. HELP!
E Upgrade Issues - Office/Outlook 2007 to 2010 Using Outlook 0
J Upgrade from 2003 to 2007 Outlook VBA and Custom Forms 14
S Upgrade Outlook 2007 to outlook with Buisiness Contact m|Manger BCM (Business Contact Manager) 2
B Upgrade to 2007, Action stopped working Outlook VBA and Custom Forms 3
B Upgrade 2003 BCM to 2007 BCM BCM (Business Contact Manager) 3
T Custom form created in 2003 won't print since upgrade to 2007 Outlook VBA and Custom Forms 1
T Custom form created in 2003 won't print since upgrade to 2007 Outlook VBA and Custom Forms 13
T upgrade from outlook.com to Outlook Using Outlook 2
T How do I upgrade from outlook.com to Outlook? Using Outlook 5
M re-Attaching PSTs after upgrade to 2016 Using Outlook 0
M Upgrade in Progress. Your mailbox is currently being optimized as part of upgrade to Outlook 2010 Using Outlook 9
Diane Poremsky How to Upgrade to Color Categories Using Outlook 0
P Outlook 2013 search broken after upgrade from 2010 Using Outlook 0
W Outlook 2013 - 2nd acct stopped receiving email after Win 8.1 upgrade Using Outlook 3
U BCM upgrade help BCM (Business Contact Manager) 0
F Which upgrade should I go for and how do I do it please? Using Outlook 2
H Outlook 2010 unable to send iCloud account e-mail after iOS 7 upgrade Using Outlook 12
B Two Inboxes after upgrade, how to merge? Using Outlook 4
L Outlook 2002-2013 upgrade Using Outlook 3
Horsepower Upgrade advice needed Using Outlook 3
T Outlook 2010 keeps asking password after upgrade Exchange Server Administration 1
B Upgrade 2003 to 2010 and max pst file size of 2GB Using Outlook 2
E How to restore BCM Database after upgrade from Vista to Win7? BCM (Business Contact Manager) 1
J BCM no longer loads sqlserver after SP2 upgrade BCM (Business Contact Manager) 2
B Outllok 2007 License Expired issue Using Outlook 0
