Run Sript after Forward
Delnang
I have a command button to insert text into the message body.
Item.Body = Item.Body & vbCrLf & "new stuff"
The script runs before a user hits Forward, but does not run if the user
were to hit forward first. It is necessary that it run after Forward.
Is this possible?
Angie
Do you mean that you want the script is not running when you click the
command button on the forwarded item? If so, check the settings for the
Forward action in the (Actions) page on your form design to make sure the
Forward action is pointing to the your published custom form. Republish if
you need to make that change.
Sue Mosher
> Is this possible?
> Thanks,
> Angie
V Outlook macros no longer run until VB editor is opened Outlook VBA and Custom Forms 0
T Outlook 2010 Errore run-time -2147417851 (80010105) Metodo delete ContactItem non riuscito Outlook VBA and Custom Forms 0
B run scripts Using Outlook 1
P errors appear every time I run SCANPST Using Outlook 3
J VBA Run When Reply Outlook VBA and Custom Forms 4
Diane Poremsky Using Scanpst in Outlook Click to Run Using Outlook 0
B Can't run macro from QAT when emailing from Acrobat Outlook VBA and Custom Forms 0
D How to Run a Report Based on Age of Inbox Items Outlook VBA and Custom Forms 0
M Office 365 Click to run BCM (Business Contact Manager) 0
