Exchang 2007 Installation
  • Thread starter Andy C
  • Start date Views 1,913
Andy C
I am getting the following Error when trying to isntall exchange 2007 SP1 on
windows server 2008 sp 1.
Summary: 6 item(s). 0 succeeded, 1 failed.
Elapsed time: 00:00:05
Organization Preparation
Failed
Error:
The E-mail Address Policy object must have exactly one primary e-mail
address with the prefix "NS".
Elapsed Time: 00:00:05
Below are some of the details from the log output.
Yes, I am not sure how it applies. Here is some more detail from the setup
log.
10/6/2009 10:25:17 AM] [2] Beginning processing.
[10/6/2009 10:25:17 AM] [2] Administrator Active Directory session settings
are: View Entire Forest: 'True', Configuration Domain Controller:
'dc.domain.com', Preferred Global Catalog: 'dc.domain.com', Preferred Domain
Controllers: '{ dc.domain.com }'
[10/6/2009 10:25:17 AM] [2] Searching objects of type "EmailAddressPolicy"
with filter "(PolicyOptionListValue Equal System.Byte[])", scope "SubTree"
under the root "Recipient Policies".
[10/6/2009 10:25:17 AM] [2] Previous operation run on domain controller
'dc.domain.com'.
[10/6/2009 10:25:17 AM] [2] Preparing to output objects. Maximum result set
size "unlimited".
[10/6/2009 10:25:17 AM] [2] [WARNING] Object FLUIDMASTER has been corrupted
and it is in an inconsistent state. The following validation errors have
occurred:
[10/6/2009 10:25:17 AM] [2] [WARNING] The E-mail Address Policy object must
have exactly one primary e-mail address with the prefix "NS".
[10/6/2009 10:25:17 AM] [2] [WARNING] The SMTP address template
'SMTP:mad:SecondDomain.com' is invalid because it references a domain that is
not an accepted domain.
[10/6/2009 10:25:17 AM] [2] [WARNING] Object SecondDomain has been corrupted
occurred:
with filter "(PolicyOptionListValue NotEqual System.Byte[])", scope "SubTree"
[10/6/2009 10:25:17 AM] [2] [WARNING] There are recipient policy object(s)
that do not contain e-mail address properties. Those policies are not shown
unless you use the parameter "IncludeMailboxSettingOnlyPolicy" in the
Get-EmailAddressPolicy command.
[10/6/2009 10:25:17 AM] [2] Ending processing.
[10/6/2009 10:25:17 AM] [2] Beginning processing.
[10/6/2009 10:25:17 AM] [2] Processing object "SecondDomain.com".
[10/6/2009 10:25:17 AM] [2] [ERROR] The E-mail Address Policy object must
[10/6/2009 10:25:17 AM] [1] The following 1 error(s) occurred during task
execution:
[10/6/2009 10:25:17 AM] [1] 0. ErrorRecord: The E-mail Address Policy
object must have exactly one primary e-mail address with the prefix "NS".
Microsoft.Exchange.Data.DataValidationException: The E-mail Address Policy
at Microsoft.Exchange.Data.Directory.ADSession.Save(ADObject
instanceToSave, IEnumerable`1 properties)
at
Microsoft.Exchange.Management.SystemConfigurationTasks.SetAcceptedDomain.DomainEditValidator.HandleNonAuthoritativeDomains(EmailAddressPolicy
policy, HashSet`1 domains)
at
Microsoft.Exchange.Management.SystemConfigurationTasks.UpdateEmailAddressPolicy.DomainValidator.Validate(EmailAddressPolicy policy)
at
Microsoft.Exchange.Management.SystemConfigurationTasks.SetAcceptedDomain.DomainEditValidator.ValidateAllPolicies()
at
Microsoft.Exchange.Management.SystemConfigurationTasks.NewAcceptedDomain.InternalValidate()
at Microsoft.Exchange.Configuration.Tasks.Task.ProcessRecord()
[10/6/2009 10:25:17 AM] [1] [ERROR] The E-mail Address Policy object must
[10/6/2009 10:25:17 AM] [1] Setup is halting task execution because of one
or more errors in a critical task.
[10/6/2009 10:25:17 AM] [1] Finished executing component tasks.
[10/6/2009 10:25:17 AM] [1] Ending processing.
[10/6/2009 10:25:38 AM] [0] End of Setup
[10/6/2009 10:25:38 AM] [0] **********************************************
DJdArchitex
On Oct 6, 1:03 pm, Andy C <An...> wrote:
> I am getting the following Error when trying to isntall exchange 2007 SP1on
> Failed
> Error:
> log.
> 'dc.domain.com'.
> size "unlimited".
> occurred:
> occurred:
> execution:
>    at
> Microsoft.Exchange.Management.SystemConfigurationTasks.SetAcceptedDomain.Do­mainEditValidator.HandleNonAuthoritativeDomains(EmailAddressPolicy
>    at
> Microsoft.Exchange.Management.SystemConfigurationTasks.UpdateEmailAddressPo­licy.DomainValidator.Validate(EmailAddressPolicy policy)
>    at
> Microsoft.Exchange.Management.SystemConfigurationTasks.SetAcceptedDomain.Do­mainEditValidator.ValidateAllPolicies()
>    at
> Microsoft.Exchange.Management.SystemConfigurationTasks.NewAcceptedDomain.In­ternalValidate()
1. Which server role? Or is this all on a single box?
2. Ck the perm of the account your are using? If you did not do prep
yet, install will attempt to do it prior?
DJ
