Question on ThisOutlookSession or OutAddIn.cls methods.
P
paresh
I have noticed that below code works fine when I put it in
ThisOutlookSession or in OutAddIn.cls(Add-in's class module). Is it possible
to put this code in any module(modOutlook.bas) or designer(Connect.Dsr) and
make it works?
Paresh
My code in
Private WithEvents objExpl As Outlook.Explorer
Private Sub objExpl_SelectionChange()
Set objExpl = objOutlook.ActiveExplorer 'Explorer Object
If objExpl.Selection.Count > 0 Then
For Each objMailItem In objExpl.Selection
If objMailItem.Class = olMail Then
msgbox "email item";
Michael Bauer
It works in any class module, it doesn't in a standard module (*.bas). Just
try and copy the WithEvents declaration wherever you want to. If the
compiler complaints, it doesn't work.
Best regards
Michael Bauer
Am Sun, 11 Oct 2009 02:24:01 -0700 schrieb paresh:
> Hi,
possible
and
> make it works?
> Thanks,
> Paresh
> My code in
> End If
> Next
> End If
> End Sub
P
paresh
Thanks Michael but I kept below code in Connect.Dsr file in my VB Add-in and
it never invokes SelectionChange event. Am I doing something wrong?
Private myApp As Outlook.Application
MsgBox "came here"
Dim objMailItem As Object
Set objExpl = myApp.ActiveExplorer 'Explorer Object
MsgBox "email item"
Paresh
> > Best regards
> Michael Bauer
> > Hi,
> possible
> and
> > make it works?
> > Thanks,
> > Paresh
> > My code in
> > End If
> > Next
> > End If
> > End Sub
Michael Bauer
You need to set the objExpl variable. As long as that's Nothing, you cannot
receive its events.
Best regards
Michael Bauer
Am Sun, 11 Oct 2009 19:31:01 -0700 schrieb paresh:
and
> MsgBox "came here"
> MsgBox "email item"
> End If
> Next
> End If
> End Sub
> Thanks,
> Paresh
Just
>> > > Best regards
> > Michael Bauer
> >> Hi,
> > possible
> > and
> >> make it works?
>>> Thanks,
> >> Paresh
>>> My code in
> >> End If
> >> Next
> >> End If
> >> End Sub
P
paresh
Okay got it. I will need to put below line in start up routine then.
Paresh
> receive its events.
> > Best regards
> Michael Bauer
> and
> > MsgBox "came here"
> > MsgBox "email item"
> > End If
> > Next
> > End If
> > End Sub
> > Thanks,
> > Paresh
> Just
> >> > >> Best regards
> >> Michael Bauer
> >>> Hi,
> >> possible
> >> and
> >>> make it works?
> >>> Thanks,
> >>> Paresh
> >>> My code in
> >>> End If
> >>> Next
> >>> End If
> >>> End Sub
