Re: Lost connection to Contacts with Outlook emails
  • Thread starter AWileyDog
  • Start date Views 720
AWileyDog
This was really helpful for me, too. When I upgraded from Vista Ultimate to
Win7 Pro, I tried to use Easy Transfer. But, I wanted to go back to 32bit on
Win7 (I was using 64bit Vista). Turns out, Easy Transfer does not support
this. Why? Who knows, they are just data files.
"texascathy(removespam)@hotmail.com" wrote:
> That was so helpful. I was doing everything I knew about but the grayed out
> bar stumped me. It was working fine yesterday. Adding back the outlook
> address book did the trick.
> Thanks A ton.
> > scanchick
> "Russ Valentine [MVP-Outlook]" wrote:
> > It is not unusual for the Outlook Address Book to "lose track" of the
> > connection to its Contacts Folder when you move or import your PST or update
> > your Outlook version or operating system. Use the following steps to reset
> > the connection. Note that in some instances you may actually have to remove
> > the Outlook Address Book completely from your Profile, close Outlook, and
> > then re-add it before you can get it to work.
> > Make sure the Contact folder is enabled as an email address book. Right
> > click the Contacts folder, choose Properties then Outlook Address Book. Is
> > the box to enable as email address book checked?
> > If this is grayed out...Go to Tools | Email Accounts, choose View or change
> > existing directories or address book. Is the Outlook Address Book present?
> > If it isn't listed, add it and close and restart Outlook. If it is listed,
> > then remove it and close then restart Outlook and repeat these steps to add
> > it.
> > More details available here:
> > http://support.microsoft.com/kb/287563&Product=ol2002
> > In your case, you will likely encounter far more difficult problems. Outlook
> > can barely survive an upgrade installation. It almost never survives an
> > upgrade/reversion unless you have been very careful to create a new profile
> > with each version change and to remove each version completely.
> > > > Russ Valentine
> > [MVP-Outlook]
> > "Sol N" <SolN> wrote in message
> > news:E796482B-FC95-433A-A0D4-C7997F9BA1EC@microsoft.com...
> > > Installed Office 2007, didnt' like it, un-install 2007, and re-installed
> > > 2003.
> > > Problem - Outlook email (new, reply or forward) couldn't find Contacts
> > > anymore. All Contacts data is still in Contacts module.
> > > Question - how can I connect Contacts to Outlook email system?
> > > > > > Sol N
Brian Tillman
"AWileyDog" <AWileyDog> wrote in message
news:552C7C3D-13EC-4122-8013-63183346B0B9@microsoft.com...
But the mail profile is not and it's in the mail profile where the connections
are made.
