How Do I stop OE from dnloading emails automatically after unchecking send/rcv msg at startup in options?
  • Thread starter tjdarth
  • Start date Views 1,407
tjdarth
I've been having a consistent problem with OE 6.0.6000.16386 running under
Vista? I can't find any other switches that will allow me to select this
feature. I also have Outlook 2007 installed along with other apps. from the
2007 Office package. Any help would be appreciated . . . .
Thanks . . .
Tom Johnson
A+, MCP, C#, XML, ASP.Net
Bob Lucas
Outlook Express was included with Windows XP and some earlier
versions of Windows. It is not part of Vista and will not run
under the Vista operating system.
If, as I suspect, you are using Windows Mail, this is not the
correct forum.
On a separate topic, it is preferable not to disclose your real
email address in public newsgroups, unless you want to be
bombarded with a deluge of junk mail.
And you should NEVER attach a vcf file with your contact details.
"tjdarth" <tjdarth@verizon.net> wrote in message
news:5B2F04DB-A528-4F6C-B9FA-238E60E12B3D@microsoft.com...
> running under
> select this
> apps. from the
> Thanks . . .
> > Tom Johnson
Bruce Hagen
You want to ask in the Windows Mail newsgroup. You don't have Outlook
Express.
Windows Vista Mail Newsgroup.
In your newsreader:
news://msnews.microsoft.com/microsoft.public.windows.vista.mail
On the Web:
http://www.microsoft.com/communities/newsgroups/en-us/default.aspx?dg=microsoft.public.windows.vista.mail
Bruce Hagen
MS-MVP [Mail]
Imperial Beach, CA
> the
> Thanks . . .
> > Tom Johnson
P
PA Bear [MS MVP]
IN RE your post subject: Tools | Options | General | Check for new messages
every XX minutes <=uncheck this
Windows Mail-specific newsgroup:
> the
> Thanks . . .
tjdarth
Thanks Robert (Pa Bear). I think I'm going to order new glasses tomorrow.
This will
probably do the trick. I appreciate the answer even though I am in the wrong
forum.
TomJ.
> > the
> > Thanks . . .
tjdarth
Thanks for the quick response, Bob. One reason I chose the OE forum is
because both products carry similar almost identical options that relate to
the same thing. PA Bear who also answered this thread, has offered me a way
by unchecking the "Check for new messages every xx minute(s)" box which is
stored on the General tab in Windows mail & I believe it is the same in OE.
I'll have to check this out as well.
I appreciate your insight on disclosing my real email address but am unaware
as to how to resolve this issue in Windows Mail or OE. Can you help me
resolve this issue or give me a link that lays this out in layman's terms? I
am always looking for good ways to eradicate the pesky junk mail that I
receive.
Thanks in advance . . .
Tom Johnson
> correct forum.
> > running under
> > select this
> > apps. from the
> > Thanks . . .
> > > > Tom Johnson
Bruce Hagen
You used WinMail for your first post, and the crappy Web Interface for this
one. The latter doesn't show your real address unless you go out of your way
to put it in.
In OE, and I believe WinMail is the same: Tools | Accounts | News | general
Tab, change the address from your real one. tjdarth@nospam.invalid would
work fine.
That won't rid you of anyone that got your real address already, but it will
stop future "harvests".
Bruce Hagen
MS-MVP [Mail]
Imperial Beach, CA
"tjdarth" <tjdarth> wrote in message
news:2F96A904-516C-4AAB-B6E4-21505870E117@microsoft.com...
> to
> way
> OE.
> unaware
> I
> receive.
> Tom Johnson
>> correct forum.
>> > running under
>> > select this
>> > apps. from the
>> > Thanks . . .
>> > >> > Tom Johnson
tjdarth
Thanks again for your response. I was forced to go to the crappy Web
Interface URL because Windows mail stop sending out my emails in response to
you guys answers with the following text:
The message could not be sent. The authentication setting might not be
correct for your outgoing e-mail [SMTP] server. For help solving this
problem, go to Help,
search for "Troubleshoot Windows Mail", and read the "I'm having problems
sending e-mail" section. If you need help determining the proper server
settings, please
contact your e-mail service provider.
The rejected e-mail address was 'moc.liamg@PVMraeBAP'. Subject 'Re: How Do I
stop OE from downloading emails automatically after unchecking send/rcv mug
at startup
in options? ', Account: 'incoming.verizon.net', Server:
'outgoing.verizon.net', Protocol: SMTP, Server Response: '550 5.1.2 Use
fully qualified domain
This is the first occurrence that I have ever received this type of message
and I am in the dark as to why this has started to occur!? I have not
changed one thing for this application. This appears to be your hidden
address that is being rejected by windows Mail.?
Very strange occurrences. . . . .Thanks again . . .
TomJ
name: moc.liamg@PVMraeBAP', Port: 25, Secure(SSL): No, Server Error: 550,
Error Number: 0x800CCC79
"Bruce Hagen" <Nospam@mymail.invalid> wrote in message
news:%23tZSgANNKHA.5128@TK2MSFTNGP02.phx.gbl...
> this one. The latter doesn't show your real address unless you go out of
> your way to put it in.
> general Tab, change the address from your real one. tjdarth@nospam.invalid
> would work fine.
> will stop future "harvests".
> Bruce Hagen
> MS-MVP [Mail]
> Imperial Beach, CA
>> to
>> way
>> is
>> OE.
>> unaware
>> terms? I
>> receive.
>> Tom Johnson
>>> correct forum.
>>> > running under
>>> > select this
>>> > apps. from the
>>> > Thanks . . .
>>> > >>> > Tom Johnson
Bruce Hagen
That is a Relay Error Message from your ISP. May I ask why you continue to
ask this question in the Outlook Express newsgroup when you are using
Windows Mail? They may look the same, but they are not the same. Once again,
please ask here.
In your newsreader:
On the Web:
Bruce Hagen
MS-MVP [Mail]
Imperial Beach, CA
news:uVBHa1%23NKHA.4816@TK2MSFTNGP04.phx.gbl...
> to you guys answers with the following text:
> settings, please
> I stop OE from downloading emails automatically after unchecking send/rcv
> mug at startup
> message and I am in the dark as to why this has started to occur!? I have
> not changed one thing for this application. This appears to be your hidden
> TomJ
>> tjdarth@nospam.invalid would work fine.
>> Bruce Hagen
>> MS-MVP [Mail]
>> Imperial Beach, CA
>>> to
>>> way
>>> is
>>> OE.
>>> unaware
>>> terms? I
>>> receive.
>>> Tom Johnson
>>>> correct forum.
>>>> > running under
>>>> > select this
>>>> > apps. from the
>>>> > Thanks . . .
>>>> > >>>> > Tom Johnson
F
FromTheRafters
Do you notice anything strange about that e-mail address?
> response to you guys answers with the following text:
> problems sending e-mail" section. If you need help determining the
> proper server settings, please
> How Do I stop OE from downloading emails automatically after
> unchecking send/rcv mug at startup
> Use fully qualified domain
> have not changed one thing for this application. This appears to be
> your hidden address that is being rejected by windows Mail.?
> TomJ
> 550, Error Number: 0x800CCC79
>> for this one. The latter doesn't show your real address unless you go
>> out of your way to put it in.
>> it will stop future "harvests".
>> Bruce Hagen
>> MS-MVP [Mail]
>> Imperial Beach, CA
>>> is
>>> relate to
>>> me a way
>>> which is
>>> in OE.
>>> unaware
>>> me
>>> terms? I
>>> that I
>>> receive.
>>> Tom Johnson
>>>> correct forum.
>>>> > running under
>>>> > select this
>>>> > apps. from the
>>>> > Thanks . . .
>>>> > >>>> > Tom Johnson
Michael Santovec
Look in your Outbox folder at the problem message. Look at the Message
Source (Ctrl-F3).
Do you see
in a TO, CC, BCC or FROM header?
That's not a valid e-mail address.
If not, then look at Tools, Accounts, Mail, Properties, Servers. Is my
outgoing server requires authentication checked? If so, click the
Settings button there to see if the bad e-mail address shows up.
Mike - http://TechHelp.Santovec.us
news:uVBHa1#NKHA.4816@TK2MSFTNGP04.phx.gbl...
> TomJ
>> Bruce Hagen
>> MS-MVP [Mail]
>> Imperial Beach, CA
>>> is
>>> relate to
>>> me a way
>>> which is
>>> in OE.
>>> unaware
>>> me
>>> terms? I
>>> that I
>>> receive.
>>> Tom Johnson
>>>> correct forum.
>>>> > running under
>>>> > select this
>>>> > apps. from the
>>>> > Thanks . . .
>>>> > >>>> > Tom Johnson
P
PA Bear [MS MVP]
<snicker>
>> TomJ
>>> Bruce Hagen
>>> MS-MVP [Mail]
>>> Imperial Beach, CA
>>>> is
>>>> relate to
>>>> me a way
>>>> which is
>>>> in OE.
>>>> unaware
>>>> me
>>>> terms? I
>>>> that I
>>>> receive.
>>>> Tom Johnson
>>>>> correct forum.
>>>>>> running under
>>>>>> select this
>>>>>> apps. from the
>>>>>> Thanks . . .
>>>>>> >>>>>> Tom Johnson
P
PA Bear [MS MVP]
Tip: Use the Reply Group (CTRL+G) button to post a reply to a newsgroup
thread, not the Reply (CTRL+R) button.
Here's another tip: You should be posting your Windows Mail questions here
=> news://msnews.microsoft.com/microsoft.public.windows.vista.mail
> to
> settings, please
> I
> mug
> at startup
> message
> TomJ
>> would work fine.
>> Bruce Hagen
>> MS-MVP [Mail]
>> Imperial Beach, CA
>>> to
>>> way
>>> is
>>> OE.
>>> unaware
>>> terms? I
>>> receive.
>>> Tom Johnson
>>>> correct forum.
>>>>> running under
>>>>> select this
>>>>> apps. from the
>>>>> Thanks . . .
>>>>> >>>>> Tom Johnson
