Send box will not clear
Steve
#1
I have an e-mail in my send box that i need to delete. It will not finish
sending. How do I delete it?
Steve
Bruce Hagen
#2
Is "Send Box" what you call the Outbox? If yes:
Check: File | Work Offline and in: View | Layout: Uncheck the Preview Pane.
Can you delete it now?
If not:
Tools | Options | Maintenance | Store Folder will reveal the location of
your Outlook Express files. Write the location down and navigate to it in
Windows Explorer or, copy and paste it into Start | Run.
In Windows XP, 2K & 2K3, the OE user files (DBX and WAB) are by default
marked as hidden. To view these files in Explorer, you must enable Show
Hidden Files and Folders under Start | Control Panel | Folder Options |
View.
With OE closed, find the DBX file for the Outbox.dbx and delete it. A new,
empty one will be created automatically when you open OE.
Do not archive mail in the Inbox or Sent Items. Create your own user defined
folders and move the messages you wish to save to them. Empty Deleted Items
folder daily. Although dbx files have a theoretical capacity of 2GB, I
recommend about a 300MB max for less chance of corruption.
Information about the maximum file size of the .dbx files that are used by
Outlook Express:
http://support.microsoft.com/kb/903095
After you are done, follow up by compacting your folders manually while
working *offline* and do it often.
Click on Outlook Express at the top of the folder tree so no folders are
open. Then: File | Work Offline (or double click Working Online in the
Status Bar). File | Folder | Compact all folders. Don't touch anything until
the compacting is completed.
In Tools | Options | Maintenance: Uncheck Compact messages in background and
leave it unchecked. {N/A if running XP/SP2}.
Bruce Hagen
MS-MVP [Mail]
Imperial Beach, CA
"Steve" <Steve> wrote in message
news:DCCFA918-C1F9-4999-9AD9-D0B370A9DE77@microsoft.com...
> > Steve
Steve
#3
Bruce,
Your right outbox was mistakenly stated as send. Your answwer did the trick.
Steve
> If not:
> View.
> Outlook Express:
> Bruce Hagen
> MS-MVP [Mail]
> Imperial Beach, CA
> > > > Steve
Bruce Hagen
#4
You're welcome.
Bruce Hagen
MS-MVP [Mail]
Imperial Beach, CA
news:81C26BBF-F084-4D27-B47E-2B74278A3A5D@microsoft.com...
> Bruce,
> trick.
> Thank you
> > Steve
>> Pane.
>> If not:
>> View.
>> new,
>> defined
>> Items
>> by
>> Outlook Express:
>> until
>> and
>> Bruce Hagen
>> MS-MVP [Mail]
>> Imperial Beach, CA
>> >finish
>> > >> > Steve
