How to programmatically set "Display reminders and tasks frm pstfolder
It is a lot more than a property, for one thing, the store must have the
To-Do hidden serach folders.
After restart, Outlook will check the stores in the profile to see which
ones expose To-dos.
Dmitry Streblechenko (MVP)
"vema" <vema.416kcm@invalid> wrote in message news:vema.416kcm@invalid...
> As described in http://support.microsoft.com/kb/926443 it is possible to
> display tasks, reminders, and flagged items in the To-Do Bar if you use
> a .pst file in Outlook 2007.
> The question is, how to programmatically set this property?
> > vema
Dr. Demento Programmatically encrypt email (2010) Using Outlook 10
oliv- Reduce the size of picture attachments: programmatically Outlook VBA and Custom Forms 3
B Adding controls programmatically Using Outlook 1
M programmatically make all Appointmentitem olResource Attendees unsendable Using Outlook 1
S Programmatically accessing Outlook Calendar data Using Outlook 1
R Send appointments data to a Form programmatically Outlook VBA and Custom Forms 2
M How to connect to SQL DB from outlook programmatically? Outlook VBA and Custom Forms 1
B Programmatically scheduling WebEx meetings through Outlook Outlook VBA and Custom Forms 1
N Help in programmatically setting formatting in an AppointmentItem Outlook VBA and Custom Forms 3
K Programmatically accessing Outlook properties Outlook VBA and Custom Forms 3
R Displaying a field from the field chooser programmatically Outlook VBA and Custom Forms 1
M How to programmatically select a outlook search folder? Outlook VBA and Custom Forms 1
M How to install custom mapi form programmatically? Outlook VBA and Custom Forms 1
A Programmatically duplicating BCM's "Link to Record" function BCM (Business Contact Manager) 2
B Accessing Outlook 2003 Signature Programmatically using C# Outlook VBA and Custom Forms 6
L Programmatically moving between pages in a form Outlook VBA and Custom Forms 2
S Programmatically bring up Advanced Find for contacts? Outlook VBA and Custom Forms 1
S assign task programmatically Outlook VBA and Custom Forms 2
S do Reply, Reply to All, Forward programmatically Outlook VBA and Custom Forms 2
O Cannot expand the folder. The set of folders cannot be opened. You do not have permission to log on. Using Outlook 1
e_a_g_l_e_p_i Outlook 2010 How to set default email address for website links Using Outlook 3
F how do i set a reminder in onenote 2010 Using Outlook 8
J Set Timer/Countdown on Emails? Outlook VBA and Custom Forms 3
Victor_50 Set all subfolders to not autoarchive Outlook VBA and Custom Forms 11
e_a_g_l_e_p_i Can you set reminder to specific times? Using Outlook 7
CWM030 I do not see a way to set the personal archive folder Exchange Server Administration 2
Witzker Macro to set contact reminder to next day 9:00 Outlook VBA and Custom Forms 45
O Set columns for all (sub)folders Using Outlook 8
e_a_g_l_e_p_i How to set fonts for emails in all folders in Outlook Using Outlook 1
