1. Here's a thread that needs an answer: Filter and Save Contacts to a CSV File
true location of NormalEmail.dotm???
Discussion in 'Using Outlook' started by Susanne Mohn, Nov 18, 2009.
  1. Susanne Mohn
    Susanne Mohn
    Guest
    hi,
    i have 2 computers- one has the NormalEmail.dotm in the template folder, the
    other one has two NormalEmails.dotm: one in the template folder and
    anotherone in the programm\office12 folder.
    The NormalEmail.dotm in the program folder save designs, buildingBlocks etc.
    The NormalEmail.dotm in the templates folder only save BuilindingBlocks.
    My question: which ist the "real" NormalEmail.dotm ??
    thanks for help
    Susan
  2. Roady [MVP]
    Roady [MVP]
    Guest
    The one in the Templates folder.
    The one in the Program Files folder might have been used by your
    IT-department when deploying Office.
    "Susanne Mohn" <SusanneMohn> wrote in message
    news:979494AF-06A6-4E08-9392-2BA2ABB97BB1@microsoft.com...
    > hi,
    > the
    > etc.
    > thanks for help
    > Susan
  3. Susanne Mohn
    Susanne Mohn
    Guest
    hi,
    but outlook still uses the NormalEmail.dotm in the folder program\office12
    when one is there....
    confusing...
    Susan
    > > hi,
    > > the
    > > etc.
    > > thanks for help
    > > Susan
  4. Brian Tillman
    Brian Tillman
    news:93D8200B-2504-4C1C-BDAC-5B08E50EECED@microsoft.com...
    How do you know that?
  5. VanguardLH
    VanguardLH
    Guest
  6. Susanne Mohn
    Susanne Mohn
    Guest
    I know that, because I connect the NormalEmail.dotm in the different folders
    with different designs (color & font).
    My Outlook on the laptop - that with the Normalemail.dotm takes the dotm
    form the Programs folder and not from the templates folders.
    And another goog thing: Its very easy to store Building Blocks in it: make
    a connection to the Word /Startup folder. this is not possibel with the
    normalemail.dotm in the templates folder.
    sorry about my bad english
    Susan
  7. Roady [MVP]
    Roady [MVP]
    Guest
    If you remove it from the Program Files folder, then it will use your
    Templates folder. The system is explained in the KB article VanguardLH
    provided;
    http://support.microsoft.com/kb/826839
    news:54A8FFDE-7E23-4829-AE58-916BB9360539@microsoft.com...
    > folders
    > make
    > Susan
    > > > program\office12
  8. Susanne Mohn
    Susanne Mohn
    Guest
    hi
    and its still the same in Word and outlook 2007?
    Susan
  9. Roady [MVP]
    Roady [MVP]
    Guest
    Yes, I think your findings confirmed that as well ;-)
    news:CF3491BB-EC1B-4DBA-9E64-E1439D6768B7@microsoft.com...
    > hi
    > Susan
    > "VanguardLH" wrote:
    > > > program\office12
Loading...
Share This Page
