Is MS Outlook 2010 Compatible with Exchange 2003?
  • Thread starter Razor7Tech
  • Start date Views 4,675
Razor7Tech
Hello
I took a (reckless) leap and tried to install the beta of MS Office 2010.
Word and Excel installed and ran smoothly, but Outlook would never start.
When I tried to open it, I got to the part where I select the Outlook profile
i want to use, then it would crash.
I removed the profile and created a new one. Still would crash. I decided to
return Outlook to my previous version of 2007 and test around with Word and
Excel, but I was not allowed to run Outlook 2007. It would crash at the same
place. I tried to register the msi executable, reinstall the Windows
installer, run the installer clean up agent, nothing.
I then decided to roll completely back to Office 2007. Same issues. No
installer found, errors, infinitely crash and restart Outlook. I ended up
having to roll my computer back to an earlier restore point just to get
Outlook to work again. Here are samples of the Application events that came
out of all of this. After awhile, I thought I should check to make sure
Outlook 2010 is compatible with our version of Exchange, which is 2003 and I
could not find anything when I searched Google.
Any ideas what might be going on here?
"Computer: 4XYCNG1
Description:
The description for Event ID ( 1000 ) in Source ( Microsoft Office 14 )
cannot be found. The local computer may not have the necessary registry
information or message DLL files to display messages from a remote computer.
You may be able to use the /AUXSOURCE= flag to retrieve this description; see
Help and Support for details. The following information is part of the event:
outlook.exe, 14.0.4536.1000, 4af1d60f, mapi32x.dll, 6.5.6944.0, 3edc4c40, 0,
0002f397.
Data:
0000: 41 00 70 00 70 00 6c 00 A.p.p.l.
0008: 69 00 63 00 61 00 74 00 i.c.a.t.
0010: 69 00 6f 00 6e 00 20 00 i.o.n. .
0018: 46 00 61 00 69 00 6c 00 F.a.i.l.
0020: 75 00 72 00 65 00 20 00 u.r.e. .
0028: 20 00 6f 00 75 00 74 00 .o.u.t.
0030: 6c 00 6f 00 6f 00 6b 00 l.o.o.k.
0038: 2e 00 65 00 78 00 65 00 ..e.x.e.
0040: 20 00 31 00 34 00 2e 00 .1.4...
0048: 30 00 2e 00 34 00 35 00 0...4.5.
0050: 33 00 36 00 2e 00 31 00 3.6...1.
0058: 30 00 30 00 30 00 20 00 0.0.0. .
0060: 34 00 61 00 66 00 31 00 4.a.f.1.
0068: 64 00 36 00 30 00 66 00 d.6.0.f.
0070: 20 00 69 00 6e 00 20 00 .i.n. .
0078: 6d 00 61 00 70 00 69 00 m.a.p.i.
0080: 33 00 32 00 78 00 2e 00 3.2.x...
0088: 64 00 6c 00 6c 00 20 00 d.l.l. .
0090: 36 00 2e 00 35 00 2e 00 6...5...
0098: 36 00 39 00 34 00 34 00 6.9.4.4.
00a0: 2e 00 30 00 20 00 33 00 ..0. .3.
00a8: 65 00 64 00 63 00 34 00 e.d.c.4.
00b0: 63 00 34 00 30 00 20 00 c.4.0. .
00b8: 66 00 44 00 65 00 62 00 f.D.e.b.
00c0: 75 00 67 00 20 00 30 00 u.g. .0.
00c8: 20 00 61 00 74 00 20 00 .a.t. .
00d0: 6f 00 66 00 66 00 73 00 o.f.f.s.
00d8: 65 00 74 00 20 00 30 00 e.t. .0.
00e0: 30 00 30 00 32 00 66 00 0.0.2.f.
00e8: 33 00 39 00 37 00 0d 00 3.9.7...
00f0: 0a 00 .. "
"Event Type: Error
Event Source: Microsoft Office 14
Event Category: None
Event ID: 2001
Date: 11/18/2009
Time: 2:46:32 PM
User: N/A
Computer: 4XYCNG1
Description:
The description for Event ID ( 2001 ) in Source ( Microsoft Office 14 )
Microsoft Outlook, Outlook failed to start correctly last time. Starting
Outlook in safe mode will help you correct or isolate a startup problem in
order to successfully start the program. Some functionality may be disabled
in this mode.
Do you want to start Outlook in safe mode?."
Safe mode would not work in either version, BTW.
Stephen Davis
Systems Administrator Specialist
L
Lanwench [MVP - Exchange]
Razor7Tech <Razor7Tech> wrote:
> Hello
> 2010. Word and Excel installed and ran smoothly, but Outlook would
> never start. When I tried to open it, I got to the part where I
> select the Outlook profile i want to use, then it would crash.
> decided to return Outlook to my previous version of 2007 and test
> around with Word and Excel, but I was not allowed to run Outlook
> 2007. It would crash at the same place. I tried to register the msi
> executable, reinstall the Windows installer, run the installer clean
> up agent, nothing.
> ended up having to roll my computer back to an earlier restore point
> just to get Outlook to work again. Here are samples of the
> Application events that came out of all of this. After awhile, I
> thought I should check to make sure Outlook 2010 is compatible with
> our version of Exchange, which is 2003 and I could not find anything
> "Computer: 4XYCNG1
> Description:
> ) cannot be found. The local computer may not have the necessary
> registry information or message DLL files to display messages from a
> remote computer. You may be able to use the /AUXSOURCE= flag to
> retrieve this description; see Help and Support for details. The
> following information is part of the event: outlook.exe,
> 0002f397.
> Data:
> 00f0: 0a 00 .. "
> "Event Type: Error
> Event ID: 2001
> Date: 11/18/2009
> Time: 2:46:32 PM
> User: N/A
> Computer: 4XYCNG1
> Description:
> following information is part of the event: Microsoft Outlook,
> Outlook failed to start correctly last time. Starting Outlook in
> safe mode will help you correct or isolate a startup problem in order
> disabled in this mode.
I don't have any experience with Outlook 2010 but I'd say it looks like it
left a lot of shards. I would probably wipe the box and start over - it's
usually the quickest route back. That is, unless you took an image-based
backup of the machine prior to installing the beta.
You shoud try running betas in VMs if you don't have spare hardware - a
great way to test.
