1. Here's a thread that needs an answer: Find the Distribution Lists a Contact Belongs to
Messages Not Going To InBox
Discussion in 'Using Outlook' started by Chris LeFebvre, Nov 22, 2009.
  1. Chris LeFebvre
    Chris LeFebvre
    Guest
    I'm using Outlook 2007 (which I upgraded from Office 2003) which I've
    been using for six months. Suddenly the last couple days I noticed that
    I didn't seem to have any new messages in my inbox. I logged into my
    Comcast email through the web mail interface and saw that I had about
    ten messages in my inbox and when I logged out and started Outlook and
    send receive finished I still did not have any new messages in my inbox.
    I tried logging back into the web mail and all the messages were gone.
    I realize that the default pst file format only supports up to a certain
    file size, I checked and the current size was 1.4gb. Still, just in
    case I created a new pst file with the latest format and copied the
    contents of the old file to the new, shut down Outlook and renamed the
    files and started Outlook up and hit send / receive and apparently I
    still have the same problem.
    Does anyone have any idea what could be going on here?
    Chris
  2. Brian Tillman
    Brian Tillman
    "Chris LeFebvre" <LeFebvreC@Comcast.Net> wrote in message
    news:OMRf8R4aKHA.5976@TK2MSFTNGP05.phx.gbl...
    > I'm using Outlook 2007 (which I upgraded from Office 2003) which I've been
    > using for six months. Suddenly the last couple days I noticed that I didn't
    > seem to have any new messages in my inbox. I logged into my Comcast email
    > through the web mail interface and saw that I had about ten messages in my
    > inbox and when I logged out and started Outlook and send receive finished I
    > still did not have any new messages in my inbox. I tried logging back into
    What view are you using? Does your "Unread Mail" search folder show them? Do
    you have any rules? Are they in your Junk E-mail folder? Do you scan
    incoming messages with an anti-virus or -spam program?
    A Unicode PST can hold one terabyte, with the default maximum size of 20GB.
    Only if you're using an old format ANSI PST are you limited to 2GB.
    > Still, just in case I created a new pst file with the latest format and
    > copied the contents of the old file to the new, shut down Outlook and
    > renamed the files and started Outlook up and hit send / receive and
    > apparently I still have the same problem.
    By doing what you describe, you've probably corrupted your mail profile. You
    cannot simply rename PSTs when they're connected with a mail profile.
  3. Chris LeFebvre
    Chris LeFebvre
    Guest
    Brian,
    > > them? Do you have any rules? Are they in your Junk E-mail folder? Do
    > > you scan incoming messages with an anti-virus or -spam program?
    I'm using the "Messages" view, same as I have since I upgraded from
    2003. The "Unread Mail" search does not show any of the new messages,
    however please see the following. I have at least twenty rules to move
    messages from various mailing lists (and I have more than one email
    account) that I'm subscribed to folders in separate Pst files
    specifically created for them, i.e.: Firebird Digests, KDE Digests,
    MySql Digests, Netbeans Digests, VNC, etc and some rules to move emails
    from my various email accounts to specific folders. They are not in my
    Junk E-Mail Folder and I use ESet NOD32 anti-virus but not their
    anti-spam enabled version so just the Outlook Junk EMail filters. EMails
    that are coming to most of the mailing lists (and my other email
    account) do seem to be appearing in their respective folders but there
    are no emails more recent than the 20th in my default InBox.
    > profile. You cannot simply rename PSTs when they're connected with a
    > mail profile.
    Seriously, how can Outlook or the profile tell the difference between
    one file called outlook.pst and another. If I created a 2nd pst file
    (lets say "Personal Folders1.pst" for example) using the latest pst
    format (not the 97-2002 format) and created within the new file the
    exact same folder structure as the old pst file and copied all the data
    from the old file to the new, then closed the new pst file, closed
    outlook, renamed the old "outlook.pst" to "outlook.pst.bad" and the new
    file from whatever name it was created with to "outlook.pst" how can
    Outlook or the profile tell the difference? In the past, on other
    computers in different situations I've used this exact technique to
    replace corrupt or damaged Pst files that ScanPst couldn't fix with no
    negative side effects.
    So the problem existed before I did this as well as after and I'm not
    getting any error messages it's just that messages being received that
    aren't automatically moved to folders in my auxiliary Pst files just
    never show up in the InBox of my default Pst file. I've run ScanPst
    against the old as well as the new pst file and it does not find any
    errors but there are messages that should be in the InBox but are not.
    - Chris
  4. Brian Tillman
    Brian Tillman
    news:u%231HrmSbKHA.5156@TK2MSFTNGP05.phx.gbl...
    If you have it configured to scan mail, uninstall it and reinstall it without
    the mail scanner.
    The mail profile contains very specific information that becomes erroneous
    when you swap files. Files are not interchangeable.
    The profile contains more information than just the PST's name. I don't know
    enough of Outlook's internals to state exactly why manipulating files in a
    profile causes problems, but it does. I've seen the outcome all too often.
    > aren't automatically moved to folders in my auxiliary Pst files just never
    > show up in the InBox of my default Pst file. I've run ScanPst against the
    > old as well as the new pst file and it does not find any errors but there
    Have you tried searching for test you know exists in one of those messages
    using, say, WIndows Desktop Search or Advanced FInd in Outlook?
  5. wangdong
    wangdong
    Guest
    Try to scan your pst file with scanpst.exe. Or you can try a 3rd part
    pst-recover tool called Advanced Outlook Repair. You can download a
    free demo version at http://www.datanumen.com/aor/aor.exe . I think
    it is a useful repair tool for you. It is easy to recover your PST
    file by using its wizard. It is a powerful tool to recover messages,
    folders and other objects from corrupt or damaged Microsoft Outlook
    PST files.
    Detailed information about Advanced Outlook Repair can be found at
    Wangdong
Loading...
Share This Page
