Office outlook 2007 window will not open why?
  • Thread starter RGlnZGFu
  • Start date Views 3,018
RGlnZGFu
I click on Outlook 2007, get the message "Cannot start Microsoft Office
Outlook. Cannot open the Outlook window." thats it, i have tries to
re-install, deleated it, scandisked it, and nothing still the same message,
no other error message attached to it.
N
Nikki Peterson
First I would try disabling and Anti-Virus, Anti-Spam, programs.
Also try disabling the firewall temporarily.
Does this work?
The Next thing to try is the Inbox Repair tool. The link below is
the Microsoft HOW TO:
http://office.microsoft.com/en-us/outlook/HP010210641033.aspx?pid=CH010496951033
If this is not effective, try creating a new profile.
- Click Start, and click Control Panel. Click Mail icon.
(If you use VISTA select the Classic View to see the
MAIL applet)
- Click Show Profiles
- In the "When starting Microsoft Office Outlook, use this
profile:" area, please select "Prompt for a profile to be used"
- Click Add and type the new profile name as you like in the
Profile name box. NOTE: Do NOT use the same name as
your original profile.
- Click Next and click Finish.
- Try to open Outlook. Choose the new profile in the
profile list and click OK.
Please let me know if and which of these is effective (or not).
Nikki
"Digdan" <Digdan> wrote in message
news:BF77C6AA-B945-4DE1-B736-8E24C5F19249@microsoft.com...
RGlnZGFu
I tried both ideas, still the same message, i did just download last night
the Outlook add on commuincator or something like that hence my problems
began,
Anyothe suggestions i am open
digdan
K
K. Orland
That information would have been very helpful to know in your original post.
Open Outlook in safe mode to see if the behaviour changes:
Start > Run > Outlook.exe /safe
> began,
> digdan
RGlnZGFu
I got in thanks, how then do I restore the outlook to its orginal login, your
suggestions would are greatly appricated.
digdan
> > began,
> > digdan
K
K. Orland
If you start Outlook in safe mode, it disables all Add Ins. If Outlook works
as intended in safe mode, it's a good bet one of your Add Ins is the culprit.
Go into Add Ins and disable them all, then start Outlook normally. Add them
back one at a time, testing inbetween, to see which one causes the problem.
> digdan
> > > began,
> > > > digdan
Moraga Betty
I am following this thread to see if I can fix the same issue. No luck so
far. Also, I cannot get Outlook to open in either regualr or safe mode. Does
that suggest anothher issue/solution? Thank you!
Betty
> > began,
> > digdan
K
K. Orland
Start > Run > outlook.exe /resetnavpane
See if that works.
"Moraga Betty" wrote:
> Hi,
> Betty
> > > began,
> > > > digdan
Moraga Betty
WOW! Worked perfectly. THANK YOU!! and thanks for such a quick reply.
What does that suggest that the problem was? Is there something I could have
done to prevent it?
Betty
> See if that works.
> > Hi,
> > Betty
> > > > began,
> > > > > > digdan
K
K. Orland
Something that's been occuring recently to lots of people. Off the top of my
head it was an update that caused it but I'd have to go have a look to make
sure. At least the solution is really easy!
> done to prevent it?
> Betty
> > See if that works.
> > > Hi,
> > > > > > Betty
> > > > > began,
> > > > > > > > digdan
C
cdemaree
I've also been getting this error. And have tried all of the above fixes.
Nothing has worked yet. Anymore suggestions?
> > done to prevent it?
> > Betty
> > > > See if that works.
> > > > > Hi,
> > > > > > > > > > Betty
> > > > > > began,
> > > > > > > > > > digdan
K
K. Orland
Your version of Outlook, type of mail account, O/S, and any error messages
would help.
> > > done to prevent it?
> > > > Betty
> > > > > > See if that works.
> > > > > > > Hi,
> > > > > > > > > > > > > > Betty
> > > > > > > began,
> > > > > > > > > > > > digdan
C
cdemaree
utlook 2007. Vista 64 bit. The error message is "Cannot start Microsoft
Office Outlook. Cannot open the Outlook window." I'm not sure what you mean
by "type of mail account". Thank you!
> would help.
> > > > done to prevent it?
> > > > > > Betty
> > > > > > > > See if that works.
> > > > > > > > > Hi,
> > > > > > > > > > > > > > > > > > Betty
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > "Digdan" wrote:
> > > > > > > > began,
> > > > > > > > > > > > > > digdan
K
K. Orland
Type of mail account as in Exchange, POP3, IMAP, etc.
> > would help.
> > > > > done to prevent it?
> > > > > > > > Betty
> > > > > > > > > > See if that works.
> > > > > > > > > > > Hi,
> > > > > > > > > > > > > > > > > > > > > > Betty
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > "Digdan" wrote:
> > > > > > > > > began,
> > > > > > > > > > > > > > > > digdan
C
cdemaree
> > > would help.
> > > > > > done to prevent it?
> > > > > > > > > > Betty
> > > > > > > > > > > > See if that works.
> > > > > > > > > > > > > Hi,
> > > > > > > > > > > > > > > > > > > > > > > > > > Betty
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > "Digdan" wrote:
> > > > > > > > > > began,
> > > > > > > > > > > > > > > > > > digdan
C
cdemaree
Also, when I try the "Start > Run > outlook.exe /resetnavpane" I get error
message "Windows cannot find 'outlook.exe/resetnavpane'. Make sure you typed
the name correctly, and then try again."
> > > would help.
> > > > > > done to prevent it?
> > > > > > > > > > Betty
> > > > > > > > > > > > See if that works.
> > > > > > > > > > > > > Hi,
> > > > > > > > > > > > > > > > > > > > > > > > > > Betty
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > "Digdan" wrote:
> > > > > > > > > > began,
> > > > > > > > > > > > > > > > > > digdan
K
K. Orland
Are you typing it exactly, with a space between outlook.exe and
/resetnavpane ?
"cdemaree" <cdemaree> wrote in message
news:13E353EB-5D15-41AA-82BE-DA81576F62A9@microsoft.com...
typed
Microsoft
you mean
messages
> > > > would help.
above fixes.
the top of my
look to make
reply.
> > > > > > > done to prevent it?
> > > > > > > > > > > > Betty
> > > > > > > > > > > > > > See if that works.
> > > > > > > > > > > > > > > Hi,
issue. No luck so
or safe mode. Does
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Betty
your original post.
changes:
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > "Digdan" wrote:
download last night
hence my problems
> > > > > > > > > > > began,
> > > > > > > > > > > > > > > > > > > > digdan
i have tries to
C
cdemaree
Thank you. That worked. But...all of my email accounts are gone. And my
appointments in the calendar have lost the categories and I can't search my
calendar. Is that just a side effect?
> /resetnavpane ?
> typed
> Microsoft
> you mean
> messages
> > > > > would help.
> above fixes.
> the top of my
> look to make
> reply.
> > > > > > > > done to prevent it?
> > > > > > > > > > > > > > Betty
> > > > > > > > > > > > > > > > See if that works.
> > > > > > > > > > > > > > > > > Hi,
> issue. No luck so
> or safe mode. Does
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Betty
> your original post.
> changes:
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > "Digdan" wrote:
> download last night
> hence my problems
> > > > > > > > > > > > began,
> > > > > > > > > > > > > > > > > > > > > > digdan
> i have tries to
K
K. Orland
No. It resets the navigation panes only. You may have another issue going
on.
Your email accounts are gone or your email is gone?
news:AE2434C6-7919-47DC-ADAF-F271ACB15F15@microsoft.com...
my
> > /resetnavpane ?
error
> > typed
> > Microsoft
what
> > you mean
error
> > messages
> > > > > > would help.
> > above fixes.
Off
> > the top of my
a
> > look to make
quick
> > reply.
> > > > > > > > > done to prevent it?
> > > > > > > > > > > > > > > > Betty
> > > > > > > > > > > > > > > > > > See if that works.
> > > > > > > > > > > > > > > > > > > Hi,
same
> > issue. No luck so
regualr
> > or safe mode. Does
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Betty
know in
> > your original post.
> > changes:
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > "Digdan" wrote:
just
> > download last night
that
> > hence my problems
> > > > > > > > > > > > > began,
> > > > > > > > > > > > > > > > > > > > > > > > digdan
it,
> > i have tries to
nothing
C
cdemaree
My email accounts, all my emails and all of my contacts are gone.
> on.
> my
> > > /resetnavpane ?
> error
> > > typed
> > > Microsoft
> what
> > > you mean
> error
> > > messages
> > > > > > > would help.
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > "cdemaree" wrote:
> > > above fixes.
> Off
> > > the top of my
> a
> > > look to make
> quick
> > > reply.
> > > > > > > > > > done to prevent it?
> > > > > > > > > > > > > > > > > > Betty
> > > > > > > > > > > > > > > > > > > > See if that works.
> > > > > > > > > > > > > > > > > > > > > Hi,
> same
> > > issue. No luck so
> regualr
> > > or safe mode. Does
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > Betty
> know in
> > > your original post.
> > > changes:
> > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > > "Digdan" wrote:
> just
> > > download last night
> that
> > > hence my problems
> > > > > > > > > > > > > > began,
> > > > > > > > > > > > > > > > > > > > > > > > > > digdan
> it,
> > > i have tries to
> nothing
