Questions about steps to upgrade Ex07 to SP2 w a CCR cluster
  • Thread starter Mike O.
  • Start date Views 1,396
Mike O.
This weekend, we're planning to apply SP2 to our Exchange 2007 environment.
We currently have two HUB/CAS servers and two Mailbox servers in a CCR
cluster, everything running on Windows 2003 R2.
Since the initial setup early last year, I've installed the various Windows
patches and Exchange rollups, but this is the first time I'll be installing
an Exchange service pack into our cluster (when we started, we used Exchange
2007 with SP1 already included)
I've done some research and believe I have the correct sequence, but I just
wanted to make sure I'm not missing anything.
1. Update each HUB/CAS server
2. On the CCR cluster inactive node, run "setup /Mode:upgrade" from command
prompt
3.Reboot server
4. Stop clustered mailbox server using Powershell or EMC
5. Move clustered mailbox server to passive node using Powershell or EMC
6. Update the CMS (setup /upgradeCMS) from command prompt
7. Go to original active node (now the passive one) Setup /Mode:Upgrade from
command prompt
I know while the CMS is being upgraded that users won't be able to access
email. Is there any way to estimate the outage window? We have fairly
recent hardware (four dual core 3Ghz processors, 32GB of RAM), and about
5,000 users
Any comments would be appreciated.
Mike O.
E
Ed Crowley [MVP]
First, Exchange 2007 SP2 includes a schema update. You may want to run the
setup.com /PrepareSchema, /PrepareAD and /PrepareDomain steps separately
before you update the server if you haven't already.
I don't think you need step 4. Where did you read that you need to stop the
CMS?
Ed Crowley MVP
"There are seldom good technological solutions to behavioral problems."
"Mike O." <MikeO> wrote in message
news:761971E0-087A-4BF4-AB69-3905DBEA347E@microsoft.com...
> environment.
> Windows
> installing
> Exchange
> just
> command
> prompt
> 3.Reboot server
> from
> command prompt
> 5,000 users
> Mike O.
Mike O.
I knew it had a schema update, one of the reasons I want to go with SP2 now
is so that we can get ready for Exchange 2010, probably sometime next
month.. I was wondering about the schema changes, though, whether it
automatically went in as part of the first system I applied SP2, or if I had
to install it separately (sounds like I should run it first). If/when the
schema update is running, does it affect any active systems? I assume I
need to wait until it's done before I start applying SP2 to the systems and
was wondering if I could start the schema update prior to my maintenance
"outage" window.
As for the stopping the CMS, my list was pretty much taken from this:
http://technet.microsoft.com/en-us/library/bb676320(EXCHG.80).aspx
steps 8 and 9 say to stop the clustered mailbox server and then move it to
the updated, previously passive node.
This also matches
http://www.messagingtalk.org/ms-exchange-server-2007-sp1-upgrade-sp2-part-2
and some other sites.
Is there any kind of estimate available as to how long the CMS upgrade will
take? We have a maintenance window, and I think I've allowed plenty of
time, but I was just wondering so that I know how long after I start it
before I need to start getting worried...
Mike O.
"Ed Crowley [MVP]" <curspice@nospam.net> wrote in message
news:u8cQ%23wUfKHA.1112@TK2MSFTNGP04.phx.gbl...
> the setup.com /PrepareSchema, /PrepareAD and /PrepareDomain steps
> separately before you update the server if you haven't already.
> the CMS?
> > Ed Crowley MVP
> > environment.
> > Windows
> > installing
> > Exchange
> > just
> > command
> > prompt
> > 3.Reboot server
> > from
> > command prompt
> > 5,000 users
>> Mike O.
E
Ed Crowley [MVP]
I stand corrected. I guess I haven't applied SP2 on existing systems, just
installed it new.
Ed Crowley MVP
"Mike O." <putthespam@thecan.com> wrote in message
news:e2zA0xgfKHA.5036@TK2MSFTNGP04.phx.gbl...
> had to install it separately (sounds like I should run it first). If/when
> the schema update is running, does it affect any active systems? I assume
> I need to wait until it's done before I start applying SP2 to the systems
> and was wondering if I could start the schema update prior to my
> maintenance "outage" window.
> This also matches
> will take? We have a maintenance window, and I think I've allowed
> plenty of time, but I was just wondering so that I know how long after I
> start it before I need to start getting worried...
> Mike O.
> > the CMS?
> > > > Ed Crowley MVP
> >> environment.
> >> Windows
> >> installing
> >> Exchange
> >> just
> >> command
> >> prompt
> >> 3.Reboot server
> >> from
> >> command prompt
> >> access
> >> 5,000 users
>>> Mike O.
Mike O.
No problem.
Any information about the other questions about whether the schema update
can be done without disrupting "live" systems and any estimate on the
updateCMS outage time?
news:OCo8W4ifKHA.2780@TK2MSFTNGP05.phx.gbl...
> installed it new.
> > Ed Crowley MVP
> >now is so that we can get ready for Exchange 2010, probably sometime next
> >If/when the schema update is running, does it affect any active systems?
> >I assume I need to wait until it's done before I start applying SP2 to the
> >systems and was wondering if I could start the schema update prior to my
> > to the updated, previously passive node.
>> This also matches
>> Mike O.
> >> the CMS?
> >> > >> Ed Crowley MVP
> >>> environment.
> >>> Windows
> >>> installing
> >>> Exchange
> >>> just
> >>> command
> >>> prompt
> >>> 3.Reboot server
> >>> EMC
> >>> from
> >>> command prompt
> >>> access
> >>> about
> >>> 5,000 users
>>>> Mike O.
E
Ed Crowley [MVP]
My experience with that schema change and others is that they don't affect
anything in your network except potentially causing some extra replication.
Ed Crowley MVP
news:uqyIV1rfKHA.3792@TK2MSFTNGP02.phx.gbl...
> No problem.
> >just installed it new.
> > > > Ed Crowley MVP
>>> This also matches
>>> Mike O.
> >>> stop the CMS?
> >>> > >>> Ed Crowley MVP
> >>>> environment.
> >>>> Windows
> >>>> installing
> >>>> Exchange
> >>>> just
> >>>> command
> >>>> prompt
> >>>> 3.Reboot server
> >>>> EMC
> >>>> /Mode:Upgrade from
> >>>> command prompt
> >>>> access
> >>>> fairly
> >>>> about
> >>>> 5,000 users
>>>>> Mike O.
Mike O.
I guess I was wondering that since it was dealing with Exchange specific
items, would it affect our Exchange 2007 systems if I start the schema
install while the Email systems are up.
news:ea30ZEsfKHA.4636@TK2MSFTNGP04.phx.gbl...
> replication.
> > Ed Crowley MVP
> > No problem.
> >> > >> Ed Crowley MVP
> >>>next month.. I was wondering about the schema changes, though, whether
> >>>it automatically went in as part of the first system I applied SP2, or
> >>>if I had to install it separately (sounds like I should run it first).
> >>>the systems and was wondering if I could start the schema update prior
> >>>to my maintenance "outage" window.
>>>> This also matches
> >>> I start it before I need to start getting worried...
>>>> Mike O.
> >>>> run the setup.com /PrepareSchema, /PrepareAD and /PrepareDomain steps
> >>>> stop the CMS?
> >>>> > >>>> Ed Crowley MVP
> >>>> problems."
> >>>>> environment.
> >>>>> CCR
> >>>>> Windows
> >>>>> installing
> >>>>> Exchange
> >>>>> I just
> >>>>> command
> >>>>> prompt
> >>>>> 3.Reboot server
> >>>>> EMC
> >>>>> /Mode:Upgrade from
> >>>>> command prompt
> >>>>> access
> >>>>> fairly
> >>>>> about
> >>>>> 5,000 users
>>>>>> Mike O.
Andrew Hodgson
On Thu, 17 Dec 2009 00:27:23 -0500, "Mike O." <putthespam@thecan.com
Not at all. I have done two of these, the first I did the schema
update during office hours then did the SP update later on, the second
I just did the SP update and it did the schema update (because it
connected to our schema master DC), both times went through fine.
On the second time I did the update first on a HT server, and it
detected the schema modifications were necessary.
Andrew.
Mike O.
Sounds good. I'm starting the update on the first HT server now...
"Andrew Hodgson" <andrew@hodgsonfamily.org> wrote in message
news:kkaqi5dtq9b94fn99kjjcrp20k70iheugm@news.giganews.com...
> Andrew.
Mike O.
Just wanted to update the process.
I went ahead and ran the GUI on the first hub server, and let it do the
schema changes, no problems.
On the second hub server, it went through the pre-requesites, but when it
started the actual patch it failed saying that it couldn't stop the transport
service. I tried re-running the patch, but it then failed saying it
couldn't access the remote registry and IIS services. I rebooted and got the
same thing. I then noticed that the IIS and remote registry services had
been "disabled", apparently by the patches first attempt. I enabled them and
restarted them, then ran the patch again and this time it worked.
The CCR udpates went perfect. The big question I had was about the time for
the "updateCMS". It was only about 10 minutes and everything came up OK.
Other than having to install the installer 4.5 and reboot before applying
the patch, the whole process wasn't too bad. When the patch failed on the
first hub server it would have been nice if it would have re-enabled the
services it turned off, though.
Thanks for the comments.
Mike O.
