1. Here's a thread that needs an answer: Forward Messages that were not Replied To
Problem in permanent type add-in toolbar
Discussion in 'Outlook VBA and Custom Forms' started by paresh, Dec 15, 2009.
  1. paresh
    paresh
    Guest
    Hi, I have been facing a issue with dealing with my add-in toolbar. I want to
    make my toolbar permanent so that use can hide and reposition it
    permanently(even after restarting Outlook). At the same time, I want to
    support my add-in toolbar for all opened Outlook explorer.
    I want to make sure that at any point of time there must be one and only one
    toolbar on any Outlook window. I have tried below methods but none worked:
    1. Tried deleting toolbar on shutdown. This doesn't delete the toolbar and
    each restarting outlook adds new toolbar.
    Private Sub AddinInstance_OnBeginShutdown(custom() As Variant)
    MyCommandBar.Delete
    Private Sub AddinInstance_Terminate()
    MyCommandBar.Delete
    2. I tried deleting toolbar on Explorer close event but didn't work.
    Whenever I open Outlook folder by right clicking it and selecting "Open in
    new window", it keep adding new toolbar but does't delete.
    Private Sub myExpl_Close()
    MyCommandBar.Delete
    If out_appt.Explorers.Count < 1 Then
    Set myExpl = Nothing
    Set myColExpl = Nothing
    3. Tried checking existence of toolbar but this will not add toolbar when I
    right click on outlook folder and open in new window.
    Set MyCommandBar = myExpl.CommandBars.Item(TOOLBARNAME)
    If Not MyCommandBar Is Nothing Then
    MsgBox "exists"
    Could anyone please help me here. I think if I can do any of below then I
    would all set here:
    1. Delete existing toolbar while closing explorer event
    2. Check the existing of toolbar explorer wise. Though I am setting
    myExpl to currently active explorer, my code always returns true for
    "myExpl.CommandBars.Item(TOOLBARNAME)" whenever I open outlook folder in new
    window.
    === MY CODE ===
    Option Explicit
    Public out_appt As Outlook.Application
    Public WithEvents MyButton As Office.CommandBarButton
    Public MyCommandBar As Office.CommandBar
    Public WithEvents myColExpl As Outlook.Explorers
    Public WithEvents myExpl As Outlook.Explorer
    Private Sub AddinInstance_OnConnection(ByVal Application As Object, _
    ByVal ConnectMode As AddInDesignerObjects.ext_ConnectMode, _
    ByVal AddInInst As Object, custom() As Variant)
    Set out_appt = Application
    Private Sub AddinInstance_OnStartupComplete(custom() As Variant)
    Set myColExpl = out_appt.Explorers
    If out_appt.Explorers.Count > 0 Then
    Call CreateToolBar
    Private Sub myColExpl_NewExplorer(ByVal Explorer As Outlook.Explorer)
    If myExpl Is Nothing Then
    Set myExpl = Explorer
    Call CreateToolBar
    MyCommandBar.Delete
    Private Sub MyButton_Click(ByVal Ctrl As Office.CommandBarButton,
    CancelDefault As Boolean)
    MsgBox "button clicked"
    Private Sub CreateToolBar()
    If out_appt.Explorers.Count = 0 Then
    Set myExpl = out_appt.ActiveExplorer
    Const TOOLBARNAME = "My Toolbar"
    ' Set MyCommandBar = myExpl.CommandBars.Item(TOOLBARNAME)
    ' If Not MyCommandBar Is Nothing Then
    ' MsgBox "exists"
    ' Exit Sub
    ' End If
    Set MyCommandBar = myExpl.CommandBars.Add(TOOLBARNAME, msoBarTop, False,
    False)
    Set MyButton = MyCommandBar.Controls.Add(msoControlButton, , "890", ,
    False)
    With MyButton
    > Caption = "&Foo Button"
    > Enabled = True
    > OnAction = "!<PermToolbarTesting.Connect>"
    > Tag = "890"
    > FaceId = 362
    > Style = 3
    > Visible = True
    MyCommandBar.Visible = True
  2. Ken Slovak - [MVP - Outlook]
    Guest
    I'll answer this one. Don't make your UI permanent. That would leave it
    there even if your addin isn't running or even if it's uninstalled. Always
    add any UI you add as temporary.
    You should be using different Explorer objects for each open Explorer in the
    Explorers collection. You add an Explorer class wrapper to a collection when
    a new Explorer is opened and remove it when it is closed. You do that in
    Explorers.NewExplorer(). The wrapper class should declare any Explorer
    events you intend to handle as well as your CommandBarButton events and
    declarations for your UI and any folder events.
    When you add an Explorer to your wrapper collection you then add the UI in
    the first Explorer.Activate() event. For an initial Explorer you bypass
    that. You hold a key value that's an index into the collection for each open
    Explorer. You add that to a Tag value to get a unique Tag value for each
    menu/toolbar/button. That way you can identify each one and get unique
    clicks for each.
    You can download a template project in VB6 that shows how to work with
    wrapper classes like that from
    http://www.slovaktech.com/outlook_2007_templates.htm, it is set up for
    Outlook 2007 use with VB6.
    "paresh" <paresh@discussions.microsoft.com> wrote in message
    news:9ADF7445-9157-41EC-AD5C-FD66C820F667@microsoft.com...
    > to
    > one
    > and
    > MyCommandBar.Delete
    > End Sub
    > MyCommandBar.Delete
    > End Sub
    > MyCommandBar.Delete
    > End If
    > End Sub
    > I
    > MsgBox "exists"
    > Exit Sub
    > End If
    > would all set here:
    > new
    > window.
    > Thanks.
    > === MY CODE ===
    > Option Explicit
    > End Sub
    > Call CreateToolBar
    > End If
    > Exit Sub
    > End Sub
    > End If
    > Call CreateToolBar
    > End If
    > End Sub
    > MyCommandBar.Delete
    > End If
    > End Sub
    > On Error Resume Next
    > End Sub
    > Exit Sub
    > End If
    > ' MsgBox "exists"
    > ' Exit Sub
    > ' End If
    > False,
    > False)
    > False)
    > With MyButton
    > .Caption = "&Foo Button"
    > .Enabled = True
    > .OnAction = "!<PermToolbarTesting.Connect>"
    > .Tag = "890"
    > .FaceId = 362
    > .Style = 3
    > .Visible = True
    > End With
    > End Sub
  3. paresh
    paresh
    Guest
    Thanks Ken but I think it is very complected way for me till I am acquainted
    with it. I am also not sure if you distinguished all explorer using objects
    then you can share the values you have loaded during startup.
    I have came out with the very simple code that meets my all requirements.
    Could you please tell me if there is anything wrong? It creates the toolbar
    on new explorer event for any new Outlook window and seem to be working fine.
    === MY CODE ====
    Option Explicit
    Public out_App As Object
    Private Sub AddinInstance_OnConnection(ByVal Application As Object, ByVal
    ConnectMode As AddInDesignerObjects.ext_ConnectMode, ByVal AddInInst As
    Set out_App = Application
    Private Sub AddinInstance_OnDisconnection(ByVal RemoveMode _
    As AddInDesignerObjects.ext_DisconnectMode, custom() As Variant)
    Set MyButton = Nothing
    Set MyCommandBar = Nothing
    Set myColExpl = out_App.Explorers
    If out_App.Explorers.Count > 0 Then
    Call CreateToolBar
    Call CreateToolBar
    If out_App.Explorers.Count < 1 Then
    Dim testIt As Boolean
    If out_App.Explorers.Count = 0 Then
    Const TOOLBARNAME = "Permanent Toolbar Testing2"
    testIt = Not out_App.ActiveExplorer.CommandBars(TOOLBARNAME) Is Nothing
    If testIt Then
    Set MyCommandBar =
    Outlook.Application.ActiveExplorer.CommandBars.Item(TOOLBARNAME)
    Set MyCommandBar =
    Outlook.Application.ActiveExplorer.CommandBars.Add(TOOLBARNAME, msoBarTop,
    False, False)
    Set MyButton = MyCommandBar.Controls.Add(msoControlButton, , "891", ,
    True)
    With MyButton
    > BeginGroup = True
    > Caption = "My Permanent Button"
    > Enabled = True
    > OnAction = "!<PermToolbarTesting2.Connect>"
    > Tag = "891"
    > FaceId = 362
    > Style = 3
    > Visible = True
    Paresh
  4. Ken Slovak - [MVP - Outlook]
    Guest
    If the code you have now meets your requirements and seems to work there's
    no need for me to review it.
    news:D2E88351-298B-4D6E-8171-EFBBA163F17D@microsoft.com...
    > acquainted
    > objects
    > toolbar
    > fine.
    > === MY CODE ====
    > Option Explicit
    > End Sub
    > End Sub
    > Call CreateToolBar
    > End If
    > End Sub
    > End If
    > Call CreateToolBar
    > End If
    > End Sub
    > End If
    > End Sub
    > End Sub
    > Exit Sub
    > End If
    > If testIt Then
    > Set MyCommandBar =
    > Else
    > Set MyCommandBar =
    > False, False)
    > End If
    > True)
    > With MyButton
    > .BeginGroup = True
    > .Caption = "My Permanent Button"
    > .Enabled = True
    > .OnAction = "!<PermToolbarTesting2.Connect>"
    > .Tag = "891"
    > .FaceId = 362
    > .Style = 3
    > .Visible = True
    > End With
    > End Sub
    > Thanks,
    > Paresh
  5. paresh
    paresh
    Guest
    Ken, actually I am just wondering why we have to write the very complex code
    to handle the toolbar for all opened Outlook windows individually? I
    understood your concept of generating TAG id uniquely after creating the
    explorer object but I haven't noticed multiple events firing when I have two
    Outlook window open and both have same toolbar "My Toolbar" with same Buttons
    and same TAGs.
    In short, could you give me a simple example where we have to use the
    concept given by you and my code will not work? I am intermediate level in
    add-in so I might not be aware of many things.
    Paresh
    > > acquainted
    > > objects
    > > toolbar
    > > fine.
    > > === MY CODE ====
    > > Option Explicit
    > > End Sub
    > > End Sub
    > > Call CreateToolBar
    > > End If
    > > End Sub
    > > End If
    > > Call CreateToolBar
    > > End If
    > > End Sub
    > > End If
    > > End Sub
    > > End Sub
    > > Exit Sub
    > > End If
    > > If testIt Then
    > > Set MyCommandBar =
    > > Else
    > > Set MyCommandBar =
    > > False, False)
    > > End If
    > > True)
    > > With MyButton
    > > .BeginGroup = True
    > > .Enabled = True
    > > .Tag = "891"
    > > .FaceId = 362
    > > .Style = 3
    > > .Visible = True
    > > End With
    > > End Sub
    > > Thanks,
    > > Paresh
  6. Ken Slovak - [MVP - Outlook]
    Guest
    Here's one example.
    You have a toggle button that indicates a state for doing something. If you
    have 2 Inspectors open and both use the same Tag value for a
    CommandBarButton, both will get the click event that toggles the button. So
    toggling in one toggles both. Then when some action is taken based on the
    button state you can't maintain separate states for the button in each
    Inspector.
    Using wrapper classes solves a number of problems such as that with unique
    Tag values, individually handling events in multiple open windows, handling
    discrete ribbon clicks that are directed to only one Inspector where you
    pass the click to a handler in your wrapper class, etc.
    Every advanced Outlook developer I know uses wrapper classes and
    collections, but your mileage may vary. I'd never do an Outlook addin myself
    without wrapper classes.
    news:2E9E6C5E-720E-45C2-8264-FE17747B909B@microsoft.com...
    > code
    > two
    > Buttons
    > and same TAGs.
    > Thanks,
    > Paresh
  7. paresh
    paresh
    Guest
    Thanks that makes perfect sense to me but I think I don't need to write
    wrapper class for explorer as my requirements are very simple and nothing is
    shared between the toolbar clicks that might cause the issue.
    What all I want is to put toolbar whenever new explorer open and perform the
    operation when button click.
    Thanks a lot for your help.
    Paresh
    wrote:
    > Here's one example.
    > Inspector.
    > > code
    > > two
    > > Buttons
    > > and same TAGs.
    > > Thanks,
    > > Paresh
Loading...
Share This Page
