Exchange Hangs and I get Topology errors
  • Thread starter deftonesman
  • Start date Views 1,953
deftonesman
I'm running a small LAN. 100 users. 2 DC's and 1 Exchange server. Everything
is 2003 STD SP2 and exchange is 2003 SP2.
Every few days, the exchange server hangs for what appears to be 2 to 4
mins. All my outlook clients get, server offline or not responding and then
it comes back.
When i check the logs i see Topology errors.
Warning:process STORE.EXE (PID=4252). Exchange Server ifmssrv1.IFMS.local
does not have Audit Security Privilege on Domain Controller
sapbld2.IFMS.local. This Domain Controller will not be used by DSAccess.
Warning:process STORE.EXE (PID=4252). The Domain Controller
sapbld2.IFMS.local is running (Unknown Operating System) (Unknown Service
Pack). DSAccess requires that Domain Controllers that run Windows 2000 have
at least Service Pack 3 installed.
Error:process MAD.EXE (PID=2252). All Global Catalog Servers in use are not
responding:
sapbld2.IFMS.local
Now this just started happening. I did retire a DC a few years ago and added
a new one with a new name. I checked all my roles in AD and everything still
points to my sapbl2 server. Also the master schema is still SAPBLD2.
I looked this up and found some useless info on microsofts site to check
rights and stuff, but its all normal.
ANYONE HAVE IDEAS????
Could a lack of diskspace cause this issue?
My TEMPDFRG.STM and EDB file is on my C: and usually grows until i lose
space and have to move it off to clear it up..seems to work fine when they
are small.
Just a thought?
Any ideas?
deftonesman
Really?? No One?? really?
> it comes back.
> responding:
> sapbld2.IFMS.local
> are small.
> Just a thought?
> Any ideas?
E
Ed Crowley [MVP]
Are you running something like GoExchange that defrags your store regularly?
Exchange wouldn't be creating a file named TEMPDFRG.STM unless that was the
name specified in the properties of a mailbox or public store. If you are
using something like GoExchange, get rid of it. GoExchange automates the
unnecessary. It just runs ESEUTIL /D, and that is not necessary unless you
have some kind of event that makes reclamation of space necessary.
I'm not sure the errors you list could be caused by a lack of disk space,
but you should solve any disk space issues first. The errors you list
appear to indicate some kind of network problem.
Ed Crowley MVP
"There are seldom good technological solutions to behavioral problems."
"deftonesman" <deftonesman> wrote in message
news:8B718F75-0C74-4682-8183-4B0829702FB2@microsoft.com...
> Everything
> then
> it comes back.
> have
> not
> responding:
> sapbld2.IFMS.local
> added
> still
> are small.
> Just a thought?
> Any ideas?
