Help on removing leading dash in business card view Outlook 2007
K
KCL
For some reason about 100 of my 400 contacts have a dash (-) showing in the
business card heading. Because it is leading it is alphabetizing the contacts
using the dash first. That messes everything up. The is no dash in the
company names or personal names or the file as so there is nothing to edit
out. When I switch to address card view they alphabetize correctly. Anyone
have a clue as to why this might be happening or how to fix it?
Russ Valentine
There is more to your story than you have revealed. Like the "For some
reason" part.
Outlook does not do this.
That means you did. How?
To which field are you referring? Business Card sorts by the "File As" field
by default. Is that the field you mean?
Russ Valentine
"KCL" <KCL> wrote in message
news:B02BFF3D-D431-49C3-98E7-841BE5ED5981@microsoft.com...
> the
> contacts
