1. Here's a thread that needs an answer: User designed fields not usable in contact folder views
Garbled incoming e-mails in Outlook 2003
Discussion in 'Using Outlook' started by Dan Schultz, Feb 1, 2010.
  1. Dan Schultz
    Dan Schultz
    Guest
    About xix months ago I noticed an intermittent problem with my incoming
    e-mails. Some would arrive with blank "To" fields, blank Subject lines, and
    a bunch of data that showed the body of the e-mail did not arrive completely.
    It's getting worse. My e-mail is hosted by Network Solutions. Their
    webmail works fine; the e-mails just can't seem to get from them to Outlook
    2003 in one piece all the time. The problem happens whether I go through my
    Cox Communicatitons cable modem or my ATT Laplink Cart. Is the problem with
    Outlook? Should I run "detect and repair." Should I reinstall? If I do
    reinstall, I do I make sure all my Outlook subfolders, etc. will be restored?
    Dan
  2. neo
    neo
    Guest
    The only time I have seen what you describe is when the sender sets the
    message encoding to "User Defined". If the sender sets this correctly to
    their region (e.g. Western European) then all is well. You can tell if this
    is the case by look at the header of the message as it will state the
    content type.
    /neo
    PS - reinstalling will not fix. the sender must switch to a different
    encoding type.
    "Dan Schultz" <DanSchultz@discussions.microsoft.com> wrote in message
    news:CA0BF0ED-A0B0-4037-95EA-7C4EAEF0159F@microsoft.com...
    > and
    > completely.
    > Outlook
    > my
    > with
    > restored?
    > Any help would be appreciated.
    > Thank you.
    > Dan
Loading...
Share This Page
