CreateObject(), GetObject() question
Salad
I have the following sub
Sub test()
'it doesn't matter which of these I use.
Dim olApp As Object
'Dim olApp As Outlook.Application
'always a (8007007e) error with following line.
'Set olApp = CreateObject("Outlook.Application")
'never get an error as long as Outlook is open
Set olApp = GetObject(, "Outlook.Application")
Set olApp = Nothing
MsgBox "Done"
I have a reference set to Microsoft Outlook Object Library.
I commented out the CreateObject() line because I get a runtime error
(8007007e) "Automation Error: The specified model could not be found."
It works with the GetObject() line...but only if Outlook is open. If
Outlook is closed, I get an runtime error 429 "ActiveX can't create
object. Is this normal?
Any idea of what is wrong?
Does the code run in Outlook? Then don't use any of the methods; there's
already an Application object, which you should use.
Both methods are only used if you want to access an application from
outside. For instance, from Outlook you could use CreateObject to start a
new instance of Excel, or use GetObject to access a running instance of
Excel.
Best regards
Michael Bauer
Am Fri, 19 Feb 2010 18:05:01 -0800 schrieb Salad:
> Sub test()
> Dim olApp As Object
> Set olApp = Nothing
> MsgBox "Done"
> End Sub
> Excel.
Hi Michael, Thanks for your response.
I was excited with your response when you mentioned the Application
object but got crushed when you mentioned that GetObject/CreateObject
were used from an external app. And that's the case...I am running it
from Access 2003 and setting the object for Outlook 2003. I should have
mentioned that in the original post.
Currently, the code runs fine as long as i use GetObject and Outlook is
open. CreateObject() fails with the (8007007e) error and if Outlook is
closed an error 429 (ActiveX can't create object).
My reference list contains the Microsoft Outlook 11 Object Library
C:\Program Files\Office2003\OFFICE11\msoutl.olb. I doubt if it makes a
difference but Outlook is not my default email reader.
Do you have any other suggestions?
First, use GetObject to see whether Outlook runs already. You need to catch
the error for the case that Outlook doesn't run. If it doesn't try this
instead of CreateObject:
Dim obj as Object
Set obj=New Outlook.Application
Does that work?
Best regards
Michael Bauer
Am Sat, 20 Feb 2010 08:37:56 -0800 schrieb Salad:
> > Excel.
> Dim obj as Object
> Does that work?
Hi Michael:
I ran the following code:
Sub TestIt()
Dim obj As Object
Set obj = New Outlook.Application
Set obj = Nothing
I am running it from Access. I get an "Automation Error: The specified
module could not be found."
My references are
VBA
Access Object Library
DAO 3.6 Object Library
Ole Automation
ActiveX Data Object 2.1
I deesn't seem so matter if I shuffle the order of the last 3, still get
the above error. Any other suggestions? It appears to be one of those
weird, hard to determine ones.
Is anything highlighted when the error occurs?
Best regards
Michael Bauer
Am Mon, 22 Feb 2010 08:08:04 -0800 schrieb Salad:
catch
>> Dim obj as Object
>> Does that work?
> Hi Michael:
> Sub TestIt()
> Dim obj As Object
> Set obj = Nothing
> End Sub
> My references are
> VBA
> Ole Automation
Yes, if I enter Debug mode, the line
is highlighted in the code below.
Sub TestIt1()
Dim obj As Object
Set obj = Nothing
Running from Outlook, the following fails on CreateObject. From Access,
both fail unless Outlook is open.
Sub test()
'Set olApp = CreateObject("Outlook.Application") 'fails
Set olApp = GetObject(, "Outlook.Application") 'outlook open, OK
Set olApp = Nothing
MsgBox "Done"
Who knows. Maybe I hosed Outlook playing around with it. As long as
Outlook is open all is well. If not, CreateObject and GetObject fail.
I can live with that, I simply have to adjust.
Years ago I've read that a so called script blocker could prevent you from
launching Outlook by code. I don't know any details. If that's not the case,
I've no clue what's going on.
If you can't find the solution, you could do this: Try GetObject, if it
throws an error, you know that OL isn't running. Display a MsgBox then to
ask the user to start Outlook.
Best regards
Michael Bauer
Am Tue, 23 Feb 2010 11:17:14 -0800 schrieb Salad:
> Sub TestIt1()
> Dim obj As Object
> Set obj = Nothing
> End Sub
> Sub test()
> Set olApp = Nothing
> MsgBox "Done"
> End Sub
Yeah, it's a weird issue.
That's what I do now. Thanks for your input.
J GetObject - Outlook/Excel 2007 Outlook VBA and Custom Forms 14
e_a_g_l_e_p_i Question about Outlook 2021 and Gmail Using Outlook 9
G Question marks in messages Using Outlook 2
e_a_g_l_e_p_i Question about calendar Using Outlook 5
e_a_g_l_e_p_i Question about installing my Gmail account on my iPhone but still getting messages downloaded to my desktop Outlook. Using Outlook 3
e_a_g_l_e_p_i Question about reinstalling Outlook 2021 Using Outlook 5
e_a_g_l_e_p_i question about 2-Step Verification with my gmail Using Outlook 0
D Question on removing an alias Using Outlook 1
e_a_g_l_e_p_i A few question before I decide to switch to Pop from imap Using Outlook 9
D.Moore SendAndReceive question Outlook VBA and Custom Forms 2
N Question Using Outlook 8
CWM030 Email Catagorties question Using Outlook 1
MahdeeyaAbdulla Friend's outlook question Using Outlook 1
rerun101 Question about message options Outlook VBA and Custom Forms 4
M Question: Is there a rule that will save email in Windows Explorer Outlook VBA and Custom Forms 3
M Question on address book Using Outlook 1
V Question on pop email Using Outlook 2
D a general question regarding data files Using Outlook 3
R Outlook 2007 - Email Question - POP3 to IMAP Outlook VBA and Custom Forms 11
adaminaus Quick question if i may Using Outlook 4
T Business Projects question BCM (Business Contact Manager) 0
V question about personal and shared calendars Exchange Server Administration 1
C Custom Forms: Question about retaining form information throughout the entire conversation Outlook VBA and Custom Forms 2
D OST question Exchange Server Administration 5
V iCloud question Using Outlook 3
J "Specific word in body" question Using Outlook 1
A Newb-ish question Using Outlook 2
A The hardest VBA/Outlook question yet Using Outlook 1
S DAG question Exchange Server Administration 0
P Outlook File Extension Question Using Outlook 3
J Outlook 2010 Calendaring Question Using Outlook 0
K Syncing outlook with iCloud question Using Outlook 5
T Outlook Prf/Automation question Using Outlook 2
T Settings question Using Outlook 6
D Question re: Grouping by Due Date vs. Sorting by Due Date Using Outlook 1
