help with outlook 2007
  • Thread starter Michele G
  • Start date Views 785
Michele G
I have been trying like crazy to set up microsoft outlook 2007 to work with
any of my emails but every time I configure it I get the same error message.
The set of folders can not be opened. The file
C:\documents&settings\Michele Gauvin\Local Settings\Application
Data\microsoft\outlook\michele20.ost can not be found. I have tried removing
the file as suggested in a couple of threads as well as uninstalling and
reinstalling outlook all to no avail. How do I fix this?
2
20100218
Michelle,
Are you sure you have got the correct error message. The reason I am
asking is because the file with similar extension in the said folder is:
"Outlook.nst". I don't have the file called: "MyName.ost". Please
recheck the error message and then post back.
hth
P
Peter Foldes
Michele
Do you have exchange installed. *.ost files belong to the Exchange Server. For
Outlook it the file name is *.pst
Peter
Please Reply to Newsgroup for the benefit of others
Requests for assistance by email can not and will not be acknowledged.
"Michele G" <MicheleG> wrote in message
news:61E0D5A9-D3B8-4419-B555-7907BC503DAD@microsoft.com...
Michele G
I am still getting two more error message. Both concerning Business Contact
Manager. One says it can not connect to the shared database and the other
says Cannot start business contact manager because SQL servger service is not
running. I do have BCM listed in my programs but I can not configure it. for
some reason that option is not showing up. I am absolutely positive it is
..ost showing up
"Peter Foldes" wrote:
> Michele
> > Peter
P
Peter Foldes
Michele
I believe you that it shows *.ost files . Unfortunately those files belong to the
Exchange Server. Do you have or did you have Exchange installed on your system? Let
us know
As far as the BCM issue goes ,I suggest that you post it to the BCM newsgroup where
the experts for bcm hang out
On the web:
http://www.microsoft.com/communities/newsgroups/list/en-us/default.aspx?dg=microsoft.public.outlook.bcm
Peter
news:968868B7-E5A8-448F-89B5-D01728B07C69@microsoft.com...
> .ost showing up
>> Michele
>> >> Peter
Brian Tillman
"20100218" <20100218@20100218.NET> wrote in message
news:%23%23ACjnpsKHA.4220@TK2MSFTNGP05.phx.gbl...
> Are you sure you have got the correct error message. The reason I am asking
> "Outlook.nst". I don't have the file called: "MyName.ost". Please recheck
The Outlook Connector, depending on its and Outlook's versions, may use an NST
file or it may use an OST file for its cache.
Brian Tillman
What type of account are you trying to create?
