Auto-reply with macro whether logged in to outlook or not
MattM.
I currently have a macro that I want to run whenever I recieve a new mail
message. Currently it runs under the Application_NewMail. This works when
outlook is on and logged in but how can I have it run on incoming emails when
I am logged off. Any help is appreciated. I have look into adding it in a
rule but a rule with a script wont work unless logged on.
This can never work, as your Outlook will only receive email when it is
running. Even if you use Exchange the emails are on the server and Outlook
doesn't know about them until it's started.
"MattM." <MattM.> wrote in message
news:75D8FBB4-603C-4921-9BE1-56CEEA428FEB@microsoft.com...
> Hello,
> when
Thanks. I had a feeling this was true, but you confirmed my suspisions.
> > Hello,
> > when
B Auto reply using macro include original email Using Outlook 4
A Macro in Outlook for auto-reply Using Outlook 3
M VBA Auto-Reply code for Two Mailboxes on one Outlook Session. Outlook VBA and Custom Forms 4
N VBA, Rule that will Auto Reply based on time of day Outlook VBA and Custom Forms 1
T Voting and auto reply Exchange Server Administration 3
S Outlook 2013 - Customized auto-reply message Using Outlook 10
L Auto Reply Signature Using Outlook 5
L Editing auto reply email from a shared mailbox? Exchange Server Administration 7
V Auto reply message after a specific time in a day Using Outlook 1
R Auto-reply with rule on shared mailbox Using Outlook 1
R How to auto reply with read-receipt Outlook VBA and Custom Forms 2
R Auto Reply with Original Email and any attachments Outlook VBA and Custom Forms 1
P Email address auto-completes work fine on laptop, but no longer on desktop Using Outlook 3
F Auto changing email subject line in bulk Using Outlook 2
