1. Here's a thread that needs an answer: Scheduling a Recurring Message
using outlook 2007 categories through gmail
Discussion in 'Outlook VBA and Custom Forms' started by dan knock, Mar 1, 2010.
  1. dan knock
    dan knock
    Guest
    hi everyone,
    I would like to find a way to keep outlook 2007 categories through gmail.
    Gmail use label which are show as folders in outlook.
    So it's "simple": when I put a category to an email, a script could copy this email to the right mapi folder in Gmail.
    in others PCs a script could put automatically a category to every email which are into this folder:
    ex: I put "urgent" category to an email ->copy this email to "urgent" gmail folder
    and then: in others PCs every email in "urgent" gmail folder could set to "urgent" category.
    the only pb... I don't know how to do that in VBA for outlook 2007.
    Someone could help me ?
    I'm convinced that many other users could be interested.
    greeting.
  2. dan knock
    dan knock
    Guest
    I've found this:
    It move every categorised email to a specific folder (urgent ou boulot).
    beware: this script freeze outlook a long time to achieve the operation.
    I need to link it with the event "user has check a new email in a specific folder"... if you know how, tell me :)
    Sub MoveItems()
    Dim myNamespace As Outlook.NameSpace
    Dim myFolder As Outlook.Folder
    Dim myItems As Outlook.Items
    Dim myRestrictItems As Outlook.Items
    Dim myItem As Outlook.MailItem
    Dim racine As Outlook.Folder
    Set myNamespace = Application.GetNamespace("MAPI")
    Set myFolder = _
    myNamespace.GetFolderFromID(ActiveExplorer.CurrentFolder.EntryID)
    Set myItems = myFolder.Items
    Set racine = myFolder.Parent
    Set myRestrictItems = myItems.Restrict("[Cat├ęgories] = 'urgent ou boulot'")
    For i = myRestrictItems.Count To 1 Step -1
    myRestrictItems(i).Move racine.Folders("urgent ou boulot")
  3. Michael Bauer
    Michael Bauer
    This example moves an item as soon as you categorize it. You could adopt it,
    and just copy the item instead:
    http://www.vboffice.net/sample.html?lang=en&mnu=2&smp=70&cmd=showitem
    This one shows how to assign a category as soon as it gets into a certain
    folder:
    http://www.vboffice.net/sample.html?lang=en&mnu=2&smp=42&cmd=showitem
    If you know exactly how many folders you want to watch, you could use one
    Items variable for each. For instance:
    Private WithEvents Items_1 As Outlook.Items
    Private WithEvents Items_2 As Outlook.Items
    etc.
    In Application-Startup you'd have to set every of these variables to the
    Items collection of one folder.
    Best regards
    Michael Bauer
    Am Mon, 01 Mar 2010 12:44:16 -0500 schrieb dan knock:
    > I've found this:
    > Sub MoveItems()
    > Set myFolder = _
    boulot'")
    > Next
    > End Sub
Loading...
Share This Page
