Re: Emails containing hyperlinks are not working how do I fix this
  • Thread starter YW5keTJrdw
  • Start date Views 2,059
Y
YW5keTJrdw
"Barb" wrote:
> I did as everyone has suggested, by resetting my web settings, but I still
> can't open hyperlinks in my calendar. Let me back up and explain my
> situation.
> I had Office 2003... was upgraded to 2007, but was having issues with
> various 'other' applications, so was restored to 2003. Prior to the upgrade
> I was able to insert 'linked' docs in my calendar. Then when I was upgraded
> to 2007, I was still able to inser 'linked' docs into my calendar. However,
> not that I'm back to 2003, the links I created previously in 2003 work fine,
> but those I created in 2007 don't. Any ideas as to why?
> Barb
> "Roady [MVP]" wrote:
> > Same solution, reset you default browser settings via Start-> Default
> > Programs
> > ---> > "David" <David> wrote in message
> > news:6A32AD48-5AA7-4D44-B90E-1CC0E94C61A2@microsoft.com...
> > > Same prob but I am using Vista.
> > > > "Garry944" wrote:
> > > >> I am having the same problem, but your suggestion didn't work. I did
> > >> notice
> > >> that if I go back into "program access and defaults", Internet Explorer
> > >> is
> > >> not selected. Should this stay selected?
> > >> "Computerdude" wrote:
> > >> > If you are using Windows XP, click start, and then "program access and
> > >> > defaults"
> > >> > Check "custom", and then click the down arrow on the right side of the
> > >> > window. Under the first option (default web browser), check Internet
> > >> > Explorer, then click OK. If this doesn't solve the problem (or you are
> > >> > not
> > >> > using XP) post again, and I will post a different option.
> > >> > >> > "SmeeHee" wrote:
> > >> > >> > > When I receive an email with a hyperlink if I try and click on the
> > >> > > hyperlink
> > >> > > it opens a Locate Link Browser button instead of opening the web
> > >> > > page. This
> > >> > > is especially annoying if the email has an automated unsubscribe link
> > >> > > because
> > >> > > there is no other way for me to ask them not to send the emails to me
> > >> > > any
> > >> > > more. I have broadband constantly connected so the communications is
> > >> > > not an
> > >> > > issue. Is there some setting that I can turn on?
Slightly different result when I click hyperlinks in my emails: (Am using
Vista Home Basic & Outlook 2007). When I click on the hyperlink in emails I
get this message "This operation has been cancelled due to restrictions in
effect on this computer. Please contact the system administrator. I am the
admim!! Have looked through help & microsoft online but nothing. What do I
do? Thanks
Brian Tillman
"andy2kw" <andy2kw> wrote in message
news:8557CEAB-76CF-4DF2-B0D0-4BAAA6003A94@microsoft.com...
> do? Thanks
See this: http://support.microsoft.com/kb/821692
Brian Tillman
> do? Thanks
See this as well: http://www.slipstick.com/problems/this-operation-has-been-cancelled-due-to-restrictions/
Q
QW5keTJrdw
> > do? Thanks
> Thanks Brian: when I click on the programs tab there's no "reset" button. The closest is under the security tab "Reset all zones to default level." Under "programs" there's "make default", "manage add ons", & "set program" buttons. What do you suggest, Andy (And what about if using firefox?)
Q
QW5keTJrdw
> > > do? Thanks
Temporary Solution until you can fix this: forward the email to a web-based
account eg. hotmail and you'll be able to follow the hyperlinks there.
Q
QW5keTJrdw
> "Andy2kw" <Andy2kw> wrote in message
> news:0FF5268D-B697-4FA2-9F36-94AF724EE662@microsoft.com...
> If you're using IE7 or 8, it's on the Advanced tab.
> See this: http://www.slipstick.com/problems/firefox.htm
> Thanks for repeated help. Even using correct "reset" button in IE doesn't help. And Vista doesn't have explorer... What do suggest - apart from a hammer to the cpu!!!
Brian Tillman
news:32ECD8F5-3FC2-4353-AD83-7CD51F2B0310@microsoft.com...
Of course it does. Click on My Computer in the Start menu. The window that
opens is Windows Explorer.
Q
QW5keTJrdw
Ok, when I click on "Folder Options" there are 3 tabs: "General", "View" &
"Search". How do I go from there? (The next stage of the solution you gave
the link for says "Select the File Types tab" and I've looked under the 3
tabs but there's nothing like that.) Thanks for your patience, Brian Tillman.
Brian Tillman
news:09D66FDA-111A-4D0A-81D2-CBD7B1E5EA6E@microsoft.com...
> Tillman.
Oh, yea. Vista. You'll have to use the Registry Editor and make sure the
Open action and ddeexec entry for the "htmfile" file type is correct. Use
regedit to locate
HKEY_CLASSES_ROOT\htmfile\shell\open. The "command" key should have one
string value, "(Default)", beneath it whose data is
"C:\Program Files\Internet Explorer\iexplore.exe" -nohome
including quotes and spaces. The "ddeexec" key should have a string value
"(Default)" whose data is
"file://%1",,-1,,,,,
with all punctuation. Also under ddeexec on my PC is a key "Application" with
a string value "(Default)" whose data is "IExplore" (wthout the quotes) and
another key "Topic" with a string value "(Default)" whose data is
"WWW_OpenURL".
Q
QW5keTJrdw
> > Tillman.
> regedit to locate
> "WWW_OpenURL".
> Ok. NO htmfile: the nearest I had was "htmlfile" which did have the corresponding & correct entries as you stated above. What's our next step?
Brian Tillman
news:3EE5E683-975E-42E3-B8F0-503B78F9E83F@microsoft.com...
I'm stumped. Sorry.
Q
QW5keTJrdw
Tx for all your help anyway, Brian. It'll be two of us learn something when
I do get the answer!
> I'm stumped. Sorry.
Q
QW5keTJrdw
> > I'm stumped. Sorry.
> > HELP: even if you don't know the answer but have an idea where it might be found, please let me know. Tx.
H
Hey Bob C
The "Edit Registry Key, Part 2 in the provided link
http://www.slipstick.com/problems/this-operation-has-been-cancelled-due-to-restrictions/ cured my problems. I had
tried to install both Chrom and Chromium Browsers - was not pleased so
uninstalled but the "chromHTML was still in registry.
> > do? Thanks
